[PATCH v6] tests for fenv.h functions
Fri Mar 20 19:50:02 UTC 2020
On Sun, Mar 8, 2020 at 11:02 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> I have compiled as well as executed it for RISC V architecture function Fegetround() returns error for all rounding directions other the default "FETONEAREST" I asked about it on devel to which dr Joel told that it is due to soft-float.
> So I have added its test case but they won't work on emulators.
There may be some emulator/simulator that simulates hard-float
support. You may want to investigate a little bit. That would be
helpful for testing purposes.
> thanks
> -Eshan
> On Sun, Mar 8, 2020 at 7:55 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Eshan,
>> This is looking good. Did you compile it? Execute it?  How was the output?
>> On Sat, Mar 7, 2020 at 6:51 AM Eshan dhawan <eshandhawan51 at gmail.com> wrote:
>> >  testsuites/psxtests/psxfenv01/init.c | 89 ++++++++++++++++++++++------
>> >  1 file changed, 71 insertions(+), 18 deletions(-)
>> > diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
>> > index cdb0fa596e..6d71463465 100644
>> > --- a/testsuites/psxtests/psxfenv01/init.c
>> > +++ b/testsuites/psxtests/psxfenv01/init.c
>> > @@ -46,11 +46,12 @@
>> >  #include <string.h>
>> >  #include <rtems/test.h>
>> >  #include <tmacros.h>
>> > +#include <float.h>
>> >  const char rtems_test_name[] = "PSXFENV 01";
>> >  /* forward declarations to avoid warnings */
>> > -rtems_task Init(rtems_task_argument ignored);
>> > +rtems_task Init( rtems_task_argument ignored );
>> >  /* Test Function Begins */
>> > @@ -62,28 +63,31 @@ rtems_task Init(rtems_task_argument ignored)
>> >     * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
>> > -   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
>> > -   * 'fetestexcept()' functions are supported by the architecture.
>> > +   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
>> > +   * fetestexcept() functions are supported by the architecture.
>> >     * Hence their testcases can be wrapped under #ifdef and #endif.
>> >    #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
>> >      puts( "fesetenv(FE_DFL_ENV)." );
>> > -    r = fesetenv(FE_DFL_ENV);
>> > -    if (r)
>> > +    r = fesetenv ( FE_DFL_ENV );
>> > +    if ( r ) {
>> >        printf("fesetenv ==> %d\n", r);
>> > -    rtems_test_assert( r == 0 );
>> > +    rtems_test_assert ( r == 0 );
>> > -    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
>> > -    puts( "feclearexcept(FE_ALL_EXCEPT)." );
>> > -    r = feclearexcept(FE_ALL_EXCEPT);
>> > -    if (r)
>> > +    /* Test feclearexcept() and fetestexcept() in one go. */
>> > +    puts( "feclearexcept(FE_ALL_EXCEPT)" );
>> > +    r = feclearexcept ( FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> >        printf("feclearexcept ==> 0x%x\n", r);
>> > -    r = fetestexcept( FE_ALL_EXCEPT );
>> > -    if (r)
>> > +    r = fetestexcept ( FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> >        printf("fetestexcept ==> 0x%x\n", r);
>> >      /* Test 'FE_DIVBYZERO' */
>> >      puts( "Divide by zero and confirm fetestexcept()" );
>> > @@ -91,11 +95,60 @@ rtems_task Init(rtems_task_argument ignored)
>> >      b = 1.0;
>> >      c = b/a;
>> >      (void) c;
>> > -    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
>> > +    /* Test fegetexceptflag() and fesetexceptflag() */
>> > +    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> > +      printf("fegetexceptflag ==> 0x%x\n", r);
>> > +    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
>> > +    if ( r ) {
>> > +      printf("fesetexceptflag ==> 0x%x\n", r);
>> > +    /* Test for fegetround() and fesetround()
>> > +     * They have four main macros to be tested separated by ifdef
>> > +     * Since not all architectures support them
>> > +     * The test case gets and sets the rounding directions */
>> > +#ifdef FE_TONEAREST
>> > +    rtems_test_assert ( fegetround() == FE_TONEAREST ) ;
>> > +#endif
>> > +#ifdef FE_TOWARDZERO
>> > +  r = fesetround ( FE_TOWARDZERO ) ;
>> > +  if ( r ) {
>> > +      printf("fesetround ==> 0x%x\n", r);
>> > +  rtems_test_assert ( r == 0 ) ;
>> > +  rtems_test_assert ( fegetround() == FE_TOWARDZERO ) ;
>> > +#endif
>> > +#ifdef FE_DOWNWARD
>> > +  r = fesetround ( FE_DOWNWARD );
>> > +  if ( r ) {
>> > +  rtems_test_assert ( fegetround() == FE_DOWNWARD ) ;
>> > +#endif
>> > +#ifdef FE_UPWARD
>> > +  r = fesetround ( FE_UPWARD );
>> > +  if ( r ) {
>> > +  rtems_test_assert ( fegetround() == FE_UPWARD ) ;
>> > +#endif
>> > +  r = fesetround ( FE_TONEAREST );
>> > +  if ( r ) {
>> > +#endif
>> >  #ifdef FE_DIVBYZERO
>> > -    r = feraiseexcept(FE_DIVBYZERO);
>> > +    r = feraiseexcept ( FE_DIVBYZERO ) ;
>> >      rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
>> >  #endif
>> > 2.17.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
