Sources to port fenv.h to ARM and AARCH64
Joel Sherrill
joel at rtems.org
Fri Mar 20 21:07:20 UTC 2020
On Fri, Mar 20, 2020 at 3:33 PM Eshan Dhawan <eshandhawan51 at gmail.com>
wrote:
> thanks, dr Joel
> I had gone through the musl-libc library but it doesn't have much
> architecture specific support for ARM as well as AARCH64
> It has support for s390x, m68k, powerpc64
This type of evaluation is important. The architecture may be supported in
only one implementation or one may be more complete than another.
Ignoring the license requirements of course.
> On Sat, Mar 21, 2020 at 1:32 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Mar 20, 2020 at 2:43 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>> wrote:
>>> What would be the preferred source to port fenv.h to ARM and AARCH64
>>> its implementation is present in both FreeBSD as well AS NetBSD
>>> -> ARM
>>> ---FreeBSD Source
>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>> ---NetBSD Source
>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>> ->AARCH64
>>> ---FreeBSD Source
>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/aarch64
>>> ---NetBSD Source
>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64
>> Don't forget MUSL-C Library which has a lot of architectures and
>> is appropriately licensed.
>> https://git.musl-libc.org/cgit/musl/tree/src/fenv
>> I think our the order is going to be FreeBSD, NetBSD, then other places.
>> The code drops into newlib's libm in a particular way which may require
>> some refactoring. fenv.h is shared across all ports and machine/fenv.h is
>> where port code goes. There must be an architecture specific file for each
>> method. But the entire implementation could go in one file and the others
>> be stubs. The i386 does this.
>> --joel
>>> <https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64>
>>> Thanks
>>> -Eshan
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200320/f3ddf04c/attachment.html>
