[PATCH] Creation of the Quick Start / Build Your Application section
William wbusacker at outlook.com
Fri Mar 20 23:56:25 UTC 2020
Oh, well that's slightly embarrassing. Before I submitted I tried
looking for the patch referencing that page and I didn't see anything.
Looking over what you wrote, would it be worth adding either a section
or a sub-page for building an application manually or with another build
tool such as GNU Make? Can salvage a bit of the work I did :)
On 3/19/2020 18:20, Chris Johns wrote:
> On 20/3/20 9:05 am, William wrote:
>> Been sitting on this patch for a while now, figured I should finally submit it...
> Thank you for posting the patch.
>> About a month ago I saw someone saying that they wanted to have this section of
>> the users guide added in, followed all of the steps of the userguide up to the
>> point just prior and then wrote this.
> Oh it is a shame this was not posted earlier as I have recently added a section ..
> https://docs.rtems.org/branches/master/user/start/app.html
>> One thing to note, the GDB simulation did not work, I couldn't get it to link up
>> to the SIS simulator (GDB didn't even know what `target sim` meant). That's why
>> I have written on how to use SIS directly. No idea where I could track that
>> problem down.
> To run a remote session with gdb you need to add -gdb to the SIS command line
> with the executable, start gdb, connect with `target :1234` then load and run
> (or continue).
> Chris
