GSoC Students: Submit Draft Applications
Eshan Dhawan eshandhawan51 at gmail.com
Sat Mar 21 10:50:13 UTC 2020
Will do it ASAP..
Thanks for the heads up
> On 21-Mar-2020, at 3:55 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Hello Aspiring Students,
> I wanted to let you know that you can submit and revise your
> application including your "Final" proposal as many times as you like
> in the Official website, and that you should do so now and update it
> periodically until the deadline. If you don't submit it then you can't
> get picked. "Final" is not final. :)
> Gedare
