Sources to port fenv.h to ARM and AARCH64
Joel Sherrill
joel at rtems.org
Sat Mar 21 20:00:26 UTC 2020
On Sat, Mar 21, 2020 at 3:03 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> On Sat, 21 Mar 2020, 10:29 Eshan Dhawan, <eshandhawan51 at gmail.com> wrote:
>> I went through the FreeBSD and NetBSD sources for implementation
>> In FreeBSD there is an architecture-specific implementation with
>> different header file for each architecture it supports .
>> Whereas in NetBSD there is a single fenv.h defined but each architecture
>> has its own C file to implement the functions.
>> Also FreeBSD has soft-float for ARM
>> So, I think FreeBSD would be a better option.
> Look into this discussion on mail thread:
> https://sourceware.org/legacy-ml/newlib/2017/msg00818.html
> and this patch series on newlib mailing list.
> https://sourceware.org/legacy-ml/newlib/2019/msg00418.html .
> It will help to understand the fenv-stub code.
I am having trouble finding the implementation of any fenv method in the
NetBSD code. I only am finding the weak alias mappings. Where is an example
of the body of one of the methods in any architecture?
--joel
>> On Sat, Mar 21, 2020 at 2:37 AM Joel Sherrill <joel at rtems.org> wrote:
>>> On Fri, Mar 20, 2020 at 3:33 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> thanks, dr Joel
>>>> I had gone through the musl-libc library but it doesn't have much
>>>> architecture specific support for ARM as well as AARCH64
>>>> It has support for s390x, m68k, powerpc64
>>> This type of evaluation is important. The architecture may be supported
>>> in only one implementation or one may be more complete than another.
>>> Ignoring the license requirements of course.
>>>> On Sat, Mar 21, 2020 at 1:32 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Fri, Mar 20, 2020 at 2:43 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>>>> wrote:
>>>>>> What would be the preferred source to port fenv.h to ARM and AARCH64
>>>>>> its implementation is present in both FreeBSD as well AS NetBSD
>>>>>> -> ARM
>>>>>> ---FreeBSD Source
>>>>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
>>>>>> ---NetBSD Source
>>>>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
>>>>>> ->AARCH64
>>>>>> ---FreeBSD Source
>>>>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/aarch64
>>>>>> ---NetBSD Source
>>>>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64
>>>>> Don't forget MUSL-C Library which has a lot of architectures and
>>>>> is appropriately licensed.
>>>>> https://git.musl-libc.org/cgit/musl/tree/src/fenv
>>>>> I think our the order is going to be FreeBSD, NetBSD, then other
>>>>> places.
>>>>> The code drops into newlib's libm in a particular way which may require
>>>>> some refactoring. fenv.h is shared across all ports and machine/fenv.h
>>>>> is
>>>>> where port code goes. There must be an architecture specific file for
>>>>> each
>>>>> method. But the entire implementation could go in one file and the
>>>>> others
>>>>> be stubs. The i386 does this.
>>>>> --joel
>>>>>> <https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64>
>>>>>> Thanks
>>>>>> -Eshan
>>>>>> _______________________________________________
>>>>>> devel mailing list
>>>>>> devel at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/4ef7f891/attachment-0001.html>
