Sources to port fenv.h to ARM and AARCH64
Joel Sherrill
joel at rtems.org
Sat Mar 21 20:25:54 UTC 2020
On Sat, Mar 21, 2020, 3:16 PM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> On Sun, Mar 22, 2020 at 1:30 AM Joel Sherrill <joel at rtems.org> wrote:
> > On Sat, Mar 21, 2020 at 3:03 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> >> On Sat, 21 Mar 2020, 10:29 Eshan Dhawan, <eshandhawan51 at gmail.com>
> wrote:
> >>> I went through the FreeBSD and NetBSD sources for implementation
> >>> In FreeBSD there is an architecture-specific implementation with
> different header file for each architecture it supports .
> >>> Whereas in NetBSD there is a single fenv.h defined but each
> architecture has its own C file to implement the functions.
> >>> Also FreeBSD has soft-float for ARM
> >>> So, I think FreeBSD would be a better option.
> >> Look into this discussion on mail thread:
> >> https://sourceware.org/legacy-ml/newlib/2017/msg00818.html
> >> and this patch series on newlib mailing list.
> >> https://sourceware.org/legacy-ml/newlib/2019/msg00418.html .
> >> It will help to understand the fenv-stub code.
> > I am having trouble finding the implementation of any fenv method in the
> NetBSD code. I only am finding the weak alias mappings. Where is an example
> of the body of one of the methods in any architecture?
> I have cloned this NetBSD Sources. As I can see those
> architecture-specific implemented methods here. Please correct me if I
> am looking into different than what you are looking for.
> ./lib/libm/arch/powerpc/fenv.c
> ./lib/libm/arch/sh/fenv.c
> ./lib/libm/arch/mips64/fenv.c
> ./lib/libm/arch/amd64/fenv.c
> ./lib/libm/arch/arm/fenv.c
> ./lib/libm/arch/i387/fenv.c
> ./lib/libm/arch/hppa/fenv.c
> ./lib/libm/arch/m88k/fenv.c
> ./lib/libm/arch/alpha/fenv.c
> ./lib/libm/arch/sparc64/fenv.c
> ./lib/libm/arch/aarch64/fenv.c
> ./regress/lib/libm/fenv/fenv.c
That's what I see browsing the repo.
The single file NetBSD looks easy to integrate. Would be similar to the
x86_64 or i386 there now on file layout.
Does the freebsd support more hardware variants?
> > --joel
> >>> On Sat, Mar 21, 2020 at 2:37 AM Joel Sherrill <joel at rtems.org> wrote:
> >>>> On Fri, Mar 20, 2020 at 3:33 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>>>> thanks, dr Joel
> >>>>> I had gone through the musl-libc library but it doesn't have much
> architecture specific support for ARM as well as AARCH64
> >>>>> It has support for s390x, m68k, powerpc64
> >>>> This type of evaluation is important. The architecture may be
> supported in only one implementation or one may be more complete than
> another.
> >>>> Ignoring the license requirements of course.
> >>>>> On Sat, Mar 21, 2020 at 1:32 AM Joel Sherrill <joel at rtems.org>
> wrote:
> >>>>>> On Fri, Mar 20, 2020 at 2:43 PM Eshan Dhawan <
> eshandhawan51 at gmail.com> wrote:
> >>>>>>> What would be the preferred source to port fenv.h to ARM and
> AARCH64
> >>>>>>> its implementation is present in both FreeBSD as well AS NetBSD
> >>>>>>> -> ARM
> >>>>>>> ---FreeBSD Source
> >>>>>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
> >>>>>>> ---NetBSD Source
> >>>>>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
> >>>>>>> ->AARCH64
> >>>>>>> ---FreeBSD Source
> >>>>>>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/aarch64
> >>>>>>> ---NetBSD Source
> >>>>>>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/aarch64
> >>>>>> Don't forget MUSL-C Library which has a lot of architectures and
> >>>>>> is appropriately licensed.
> >>>>>> https://git.musl-libc.org/cgit/musl/tree/src/fenv
> >>>>>> I think our the order is going to be FreeBSD, NetBSD, then other
> places.
> >>>>>> The code drops into newlib's libm in a particular way which may
> require
> >>>>>> some refactoring. fenv.h is shared across all ports and
> machine/fenv.h is
> >>>>>> where port code goes. There must be an architecture specific file
> for each
> >>>>>> method. But the entire implementation could go in one file and the
> others
> >>>>>> be stubs. The i386 does this.
> >>>>>> --joel
> >>>>>>> Thanks
> >>>>>>> -Eshan
> >>>>>>> _______________________________________________
> >>>>>>> devel mailing list
> >>>>>>> devel at rtems.org
> >>>>>>> http://lists.rtems.org/mailman/listinfo/devel
> >>> devel mailing list
> >>> devel at rtems.org
> >> devel mailing list
> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200321/93a5181a/attachment.html>
