Ticket #2974 Enable search.h functionality in newlib
Gedare Bloom
gedare at rtems.org
Sun Mar 22 00:43:26 UTC 2020
On Sat, Mar 21, 2020 at 3:17 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 21, 2020 at 2:57 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> hello,
>> I didn't quite understand the ticket
>> If I could get some more detail on it.
> Newlib has a search dirtectory:
> https://github.com/RTEMS/sourceware-mirror-newlib-cygwin/tree/master/newlib/libc/search
> Is all the code that could run on RTEMS enabled? Check which methods in there
> are built currently and which are not.
> https://pubs.opengroup.org/onlinepubs/9699919799/ is the top of the current version
> of the POSIX standard. Search for search.h and check the list off with what newlib
> has and what's enabled when building for RTEMS. You can check build logs for the
> tools or do something like CPU-rtems5-nm ...../libc.a and look for the symbol to be
> present and have a non-zero length.
> Then we address what methods are missing. And what need tests inside the
> RTEMS test suite.
> My very quick review shows that this may all be present and then it is a matter
> of test cases and the compliance document. And that's a good result. Sometimes
> people do work and don't update tickets.
My hazy recollection is that someone looked into this. Maybe in prior
POSIX Compliance projects?
> --joel
>> thanks
>> -Eshan
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
