Adding GDB BSPs to rtems-tester
Niteesh G. S. niteesh.gs at gmail.com
Sun Mar 22 07:39:30 UTC 2020
I built mips jmr3904. I was able to run rtems-run and rtems-test on it.
But cdtest.exe fails.
*** TESTING C++ EXCEPTIONS ***
mips-core: 1 byte read to unmapped address 0x2ed31 at 0x880290a4
Program received signal SIGBUS, Bus error.
0x88028fe4 in strlen ()
What is causing this error?
I tried running this manually on GDB. On forcefully continuing.
Warning, resuming with mismatched exception signal (7 vs 10)
Unhandled exception 7
sr: 0x536936196  cause: 0x00029724 --> Data Bus Error
*** FATAL ***
fatal source: 1 (INTERNAL_ERROR_RTEMS_API)
fatal code: 9800724312699699200 (0x100000000)
RTEMS version: 5.0.0.37e7cc5f4ce7ed46b5ea2de56d9066d121d851cb-modified
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (0b7e87143b76), Newlib fbaa096)
executing thread ID: 0x08a010001
executing thread name: CTOR
Is this problem with the BSP or simulator? And how can I fix this?
On Sat, Mar 21, 2020 at 11:33 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 21, 2020 at 10:38 AM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
>> Which architecture should I try then? Maybe powerpc or mips? If you have
>> any
>> of them already built can you please try them out? Building everything
>> from
>> source takes a lot of time in my dev machine.
>> On Sat, Mar 21, 2020 at 6:41 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Sat, Mar 21, 2020 at 12:54 AM Niteesh G. S. <niteesh.gs at gmail.com>
>>> wrote:
>>> > On Thu, Mar 19, 2020 at 11:43 PM Gedare Bloom <gedare at rtems.org>
>>> wrote:
>>> >> On Thu, Mar 19, 2020 at 11:56 AM Niteesh G. S. <niteesh.gs at gmail.com>
>>> wrote:
>>> >> > Hello,
>>> >> > While looking for small tasks to take up, Gedare mentioned about
>>> adding GDB BSPs
>>> >> > to rtems-tester. Can some please explain a bit more of what has to
>>> be done? I guess
>>> >> > we have to write configuration files for BSPs that support
>>> simulation in GDB. If so, how
>>> >> > could I find those BSPs, do I have to individually look at all the
>>> BSPs?
>>> >> As I said off-list, I don't know if there's a list of GDB BSPs, but I
>>> >> know of at least:
>>> >> powerpc/psim
>>> >> mips/jmr3904
>>> >> moxie/moxiesim
>>> >> arm/gdbarmsim
>>> >> sh/shsim
>>> >> I have no idea what any of their statuses are or if they are expected
>>> >> to work. The first step would be building them and see if they run
>>> >> anything. After that, you should look at the existing tester scripts
>>> for
>>> >> some targets:
>>> >>   rtems-tools.git/tester/rtems/testing/bsps
>>> >> I see scripts for most of what I listed above, so the next step would
>>> >> be trying to run them via tester and see if it works.
>>> > I built the simsh1 BSP but couldn't get it running. Before trying it
>>> with rtems-run
>>> > and rtems-test I tried manually loading it in the simulator. But gdb
>>> doesn't respond
>>> > as soon as I execute the run command. The only way to exit it was
>>> using ctrl-c and GDB
>>> > responds with
>>> > sim_events_schedule_after_signal - buffer overflow
>>> > Quit
>>> > Aborted (core dumped)
>>> > I tried setting breakpoints within GDB but it never seems to hit them.
>>> I tried running the
>>> > examples through rtems-test results in ta imeout.
>>> > Due to the slow internet connection and slow development machine, I
>>> could only build
>>> > and test a few BSPs. In case if anyone has an already built tool suite
>>> and BSP for the
>>> > mentioned arch please try them out.
>>> I don't know that anyone uses this architecture. Don't spend too much
>>> effort trying to debug the simulator :)
> mips jmr3904 and powerpc psim should work well.
> I agree with Gedare, spending a lot of time on the SH isn't high payoff.
> I'm glad for the report but there could be bitrot in the simulator or BSP.
>>> >> BTW: Did I mention adding these to tester, or did I mention creating
>>> >> build sets for them? Anyway, I think the GDB simulator builds by
>>> >> default with the toolchain, so there is no difference between a BSP
>>> >> buildset (such as for jmr3904) and one that supports running on GDB.
>>> >> At least, I think so. It is worth verifying.
>>> >> Gedare
>>> >> > Thank you,
>>> >> > Niteesh.
>>> >> > _______________________________________________
>>> >> > devel mailing list
>>> >> > devel at rtems.org
>>> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200322/48211a31/attachment-0001.html>
