[PATCH] user/gsoc: GSoC Getting Started Instructions
Niteesh G. S. niteesh.gs at gmail.com
Sun Mar 22 16:17:14 UTC 2020
On Sun, Mar 22, 2020 at 7:42 PM Gedare Bloom <gedare at rtems.org> wrote:
> Hi Niteesh,
> Did you build the docs with this change
Yes, I did. Did you face any issues?
I am sorry for typos and grammatical mistakes. I checked a couple of times
but still
missed them.
> The rewrite is nice. I do have several comments below to address:
> On Tue, Mar 17, 2020 at 2:36 PM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> >  user/index.rst       |   1 +
> >  user/start/gsoc.rst  | 453 +++++++++++++++++++++++++++++++++++++++++++
> >  user/start/index.rst |   1 +
> >  3 files changed, 455 insertions(+)
> >  create mode 100644 user/start/gsoc.rst
> > diff --git a/user/index.rst b/user/index.rst
> > index 0e644c9..f253ea6 100644
> > --- a/user/index.rst
> > +++ b/user/index.rst
> > @@ -10,6 +10,7 @@ RTEMS User Manual (|version|).
> >  .. topic:: Copyrights and License
> > +    | |copy| 2020 Niteesh Babu
> >      | |copy| 2019 Vijay Kumar Banerjee
> >      | |copy| 2018 Amaan Cheval
> >      | |copy| 2018 Marçal Comajoan Cara
> > diff --git a/user/start/gsoc.rst b/user/start/gsoc.rst
> > new file mode 100644
> > index 0000000..071c1cc
> > --- /dev/null
> > +++ b/user/start/gsoc.rst
> > @@ -0,0 +1,453 @@
> > +.. comment: SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. comment: Copyright (C) 2020 Niteesh Babu <niteesh.gs at gmail.com>
> > +.. comment: All rights reserved.
> We don't really use this phrase.
This was inspired by this source. Should I change that also?
https://devel.rtems.org/wiki/Docs/New_Chapter#License
> only 1 blank
> > +.. _QuickStartGSoC:
> > +GSoC Getting Started
> > +The goal of this page is to help you get RTEMS compiled and running so
> you can
> I think the intro at least will be better in the 3rd person for the
> manual version. Replace first "you" with "new users, especially
> students, " and replace second "you" with "they"
> > +start with the real work.
> > +Please join the :r:list:`users` and :r:list:`devel` mailing lists and
> ask questions.
> > +Help correct any deficiencies in the code or documentation you spot,
> including
> > +those on the wiki. The ultimate goal of GSoC is to help you become part
> of the
> replace "you" with "students"
> You can keep it in second-person below that is fine for now.
> > +open source community.
> > +.. _QuickStartConfigureComputer:
> > +Configure a Development Computer
> > +You will be best served by using a GNU/Linux environment, which could
> be in a
> > +virtual machine, for example that uses `Virtualbox <
> https://www.virtualbox.org/>`_
> > +and should run on most modern desktop systems. You should also be able
> to work
> > +with a MacOS or Windows system, but might encounter more difficulty
> than a *nix
> > +environment.
> > +Feel free to ask questions on the rtems-users mailing list in case you
> face
> :r:list:`users`
> > +trouble with the steps. If you want tools for another architecture,
> replace
> > +sparc in the RSB directions with another architecture, such as arm or
> mips. You
> s/another/that
> > +can also use the RSB to build RTEMS directly, but we recommend that you
> learn
> > +how to build RTEMS by itself with the compiler tools generated by RSB.
> > +As you will be compiling a lot of code, it is recommended to have a
> reasonably
> > +fast development machine.
> > +The instructions in this chapter will help you in quickly setting up a
> > +development environment. For a detailed set of instruction please refer
> to the
> typo: instructions
> > +:ref:`QuickStart` chapter.
> > +You need tools for your host’s operating system to build the RTEMS tool
> suite
> > +from source. Please have a look at the :ref:`host-computer` chapter for
> the
> > +instructions to install the tools.
> After the chapter by Utkarsh about cross-compilers is merged, it would
> be good to add a sentence here with a ref.
I'll send in a patch once his work gets merged.
> > +Choosing an Installation Prefix
> > +The term ``prefix`` refers to the path on your computer where the
> software is to
> > +be installed.
> > +In this case, we choose the home directory ``$HOME/rtems`` as our
> prefix.
> > +.. code-block:: none
> > +  mkdir $HOME/rtems
> > +Getting Sources
> > +We obtain the source code for the :ref:`RTEMS Source Builder (RSB)
> <RSB>` and
> > +RTEMS from the RTEMS :r:url:`git`.
> > +The :ref:`RTEMS Source Builder (RSB) <RSB>` is the tool used to build
> RTEMS
> > +packages from source. We will be using the RSB to build RTEMS the
> source.
> "from" missing?
> > +Please have a look at the :ref:`RTEMS Source Builder (RSB) <RSB>` for
> more
> > +information.
> > +We'll clone to the repositories to ``$HOME/rtems/src``.
> "to the" -> "the"
> > +  mkdir -p $HOME/rtems/src
> > +  cd $HOME/rtems/src
> > +  git clone git://git.rtems.org/rtems-source-builder.git rsb
> > +  git clone git://git.rtems.org/rtems.git
> > +Building the Tool suite
> > +Once you have cloned the repositories and installed the required tools
> for
> > +your host operating system. You can start building the tools suite for
> your BSP.
> > +The tools suite is the collection of compiler, debugger, Assembler and
> other
> lower case assembler
> > +tools required for developing the software.
> > +You can check if your host is set up correctly using ``sb-check`` tool
> provided
> "using the"
> > +in the RSB repository.
> > +  cd $HOME/rtems/src/rsb/source-builder
> > +  ./sb-check
> > +If you installed all the required tools you should have the following
> output.
> > +  RTEMS Source Builder - Check, 5 (0b7e87143b76)
> > +  Environment is ok
> > +.. note:: The numbers may vary depending on the RSB release.
> > +The tool suite for RTEMS and the RTEMS sources are tightly coupled. For
> example,
> > +do not use a RTEMS version 5 tool suite with RTEMS version 4.11 sources
> and vice
> "a RTEMS" -> "an RTEMS"
> > +versa. In simple words, make sure you clone both the repositories at
> the same
> > +time.
> > +The tools suite is architecture specific. In this guide we will be
> building the
> hyphenate "architecture-specific"
> comma after guide
> > +tools suite for the SPARC architecture. So the tool suite name is
> sparc-rtems5.
> > +You can build the tools suite for other architectures like ARM, RISCV by
> replace comma with "or"
> > +replacing the architecture name. For example, for ARM the tools suite
> name would
> > +be arm-rtems5.
> Does the manual have a version number macro for the specific version
> of the docs that are built? It ought to... then you could replace
> every hard-coded '5' version number here with that macro.
I have looked at common/rtemsdomain.py to see if any macro for the specific
version
was present. But I couldn't find anything. The "|version|"  is being used
in the headings
for the chapter. But it includes both RTEMS major and minor number.
|version| --> 5.927b004
> > +The following command builds and installs the tools suite in the path
> mentioned
> > +in the prefix option.
> > +  cd $HOME/rtems/src/rsb/rtems
> > +  ../source-builder/sb-set-builder --prefix=$HOME/rtems/5 5/rtems-sparc
> > +This command should output something like this (omitted lines are
> denoted by …).
> > +The build host appears as part of the name of the package being built.
> The name
> > +you see may vary depending on the host you are using:
> > +  RTEMS Source Builder - Set Builder, 5.1.0
> > +  Build Set: 5/rtems-sparc
> > +  config: tools/rtems-binutils-2.34.cfg
> > +  package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > +  building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > +  sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.866MB
> (installed: 29.966MB)
> > +  cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
> > +  reporting: tools/rtems-binutils-2.34.cfg ->
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
> sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
> > +  config: tools/rtems-gcc-7.5.0-newlib-fbaa096.cfg
> > +  package: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > +  building: sparc-rtems5-gcc-7.5.0-newlib-fbaa096-x86_64-freebsd12.1-1
> > +  Build Sizes: usage: 5.684GB total: 1.112GB (sources: 143.803MB,
> patches: 21.348KB, installed 995.188MB)
> > +  Build Set: Time 0:21:35.626294
> > +Once the build has successfully completed you can check if the cross C
> compiler
> C cross-compiler
> > +works with the following command:
> > +  $HOME/rtems/5/bin/sparc-rtems5-gcc --version
> > +This command should output something like below. The version
> information helps
> > +you to identify the exact sources used to build the cross compiler of
> your RTEMS
> > +tool suite.
> > +  sparc-rtems5-gcc (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.1.0, Newlib
> fbaa096)
> > +  Copyright (C) 2017 Free Software Foundation, Inc.
> > +  This is free software; see the source for copying conditions.  There
> is NO
> > +  warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
> PURPOSE.
> > +Add the tools suite to your ``$PATH`` by the following command:
> > +  export PATH=$HOME/rtems/5:"$PATH"
> > +This is only valid for the current terminal session. To make it
> permanant, add
> typo: permanent
> > +it your ``~/.profile`` by the following command:
> > +  echo "export PATH=$PATH:$HOME/rtems/5" >> ~/.profile
> The above about .profile is not portable and may not be the best
> practice for all users. Maybe specify simply that the PATH
> modifications can be made permanent in different ways depending on the
> host OS... and give this as one example.
> > +Bootstrap the RTEMS Source
> > +Since you have built and installed the tools required for compilation
> of RTEMS.
> Sentence fragment. Replace "Since" with "By now"
> > +It is time to build the BSP. But before that it is necessary to
> bootstrap the
> > +the build system in the RTEMS source. Bootstrap is the process where
> the files
> > +required for building RTEMS are generated. This process is required
> because
> > +RTEMS does not keep the generated files under version control.
> > +To perform bootstrap we need to enter the cloned source directory then
> run the
> > +bootstrap commands:
> > +  cd $HOME/rtems/src/rtems
> > +  ./bootstrap -c && /$HOME/rtems/src/rtems/rtems-bootstrap
> It may be better to show directions with sb-bootstrap?
> > +Build the BSP
> > +The Board Support Package (BSP) is the software that glues a specific
> board or
> > +hardware to RTEMS. For information on available BSPs you can refer to
> :ref:`BSPs`.
> > +We will be building the SPARC ERC32 BSP since we have installed the
> SPARC tools
> > +suite and also because this BSP has a robust simulator that runs the
> example and
> > +test executables on your host computer.
> > +The RSB can also be used to build the BSP. But we will be building it
> manually.
> > +You can refer to the :ref:`QuickStart` chapter for instructions on
> building it
> > +using RSB.
> > +We by choosing a build directory. It must be separate from the RTEMS
> source
> by -> start by
> > +directory. We will be using ``$HOME/rtems/build/erc32`` as our build
> directory.
> > +  mkdir -p $HOME/rtems/build/erc32
> > +We now configure the BSP. We enable all the tests. But if you want you
> can
> > +enable only a part of the tests by replacing `--enable-tests` with
> > +`--enable-tests=samples`. This would only build the tests under
> > +``$HOME/rtems/src/rtems/testsuites/samples`` and will also reduce your
> build
> > +times significantly.
> > +  cd $HOME/rtems/build/erc32
> > +  $HOME/rtems/src/rtems/configure \
> > +      --prefix=$HOME/quick-start/rtems/5 \
> > +      --enable-maintainer-mode \
> > +      --target=sparc-rtems5 \
> > +      --enable-rtemsbsp=erc32 \
> > +      --enable-tests
> denoted by ...):
> > +  checking for gmake... gmake
> > +  checking for RTEMS Version... 5.0.0
> > +  checking build system type... x86_64-unknown-freebsd12.0
> > +  checking host system type... x86_64-unknown-freebsd12.0
> > +  checking target system type... sparc-unknown-rtems5
> > +  config.status: creating Makefile
> > +  target architecture: sparc.
> > +  available BSPs: erc32.
> > +  'gmake all' will build the following BSPs: erc32.
> > +  other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
> > +The configure command will the create the Makefile required to build
> the BSP.
> s/will the create/will create
> > +We can now finally build the BSP using make.
> > +  make
> denoted by …).
> > +.. code-block::none
> > +  Configuring RTEMS_BSP=erc32
> > +  checking host system type... sparc-unknown-rtems5
> > +  checking rtems target cpu... sparc
> > +  checking for a BSD-compatible install... /usr/bin/install -c
> > +  checking whether build environment is sane... yes
> > +  checking for sparc-rtems5-strip... sparc-rtems5-strip
> > +  checking for a thread-safe mkdir -p...
> $BASE/src/rtems/c/src/../../install-sh -c -d
> > +  checking for gawk... no
> > +  checking for mawk... no
> > +  checking for nawk... nawk
> > +  checking whether gmake sets $(MAKE)... yes
> > +  checking whether to enable maintainer-specific portions of
> Makefiles... yes
> > +  checking for RTEMS_BSP... erc32
> > +  checking whether CPU supports libposix... yes
> > +  configure: setting up make/custom
> > +  configure: creating make/erc32.cache
> > +  gmake[3]: Entering directory
> '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
> > +  sparc-rtems5-gcc  -mcpu=cypress -O2 -g -ffunction-sections
> -fdata-sections -Wall -Wmissing-prototypes -Wimplicit-function-declaration
> -Wstrict-prototypes -Wnested-externs -B./../../lib/libbsp/sparc/erc32
> -B$BASE/src/rtems/bsps/sparc/erc32/start -specs bsp_specs -qrtems
> -L./../../cpukit -L$BASE/src/rtems/bsps/sparc/shared/start
> -Wl,--wrap=printf -Wl,--wrap=puts -Wl,--wrap=putchar -Wl,--gc-sections -o
> spwkspace.exe spwkspace/spwkspace-init.o
> ./../../lib/libbsp/sparc/erc32/librtemsbsp.a ./../../cpukit/librtemscpu.a
> > +  gmake[5]: Leaving directory
> '$BASE/build/b-erc32/sparc-rtems5/c/erc32/testsuites/sptests'
> > +  gmake[4]: Leaving directory
> '$BASE/build/b-erc32/sparc-rtems5/c/erc32/testsuites'
> > +  gmake[3]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
> > +  gmake[2]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c/erc32'
> > +  gmake[1]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  gmake[1]: Entering directory '$BASE/build/b-erc32'
> > +  gmake[1]: Nothing to be done for 'all-am'.
> > +  gmake[1]: Leaving directory '$BASE/build/b-erc32'
> > +The last step is installing the BSP.
> > +  make install
> denoted by …).
> > +In this output the base directory $HOME/rtems was replaced by $BASE.
> > +  Making install in sparc-rtems5/c
> > +  gmake[1]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  Making install in .
> > +  gmake[2]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  gmake[3]: Entering directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  gmake[3]: Nothing to be done for 'install-exec-am'.
> > +  gmake[3]: Nothing to be done for 'install-data-am'.
> > +  gmake[3]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  gmake[2]: Leaving directory '$BASE/build/b-erc32/sparc-rtems5/c'
> > +  Making install in erc32
> > +  Making install-am in .
> > +  Making install-am in cpukit
> > +  gmake[4]: Entering directory
> '$BASE/build/b-erc32/sparc-rtems5/c/erc32/cpukit'
> > +  gmake[5]: Entering directory
> > +  gmake[5]: Nothing to be done for 'install-exec-am'.
> > +   $BASE/src/rtems/c/src/../../cpukit/../install-sh -c -d
> '$BASE/rtems/5/sparc-rtems5/erc32/lib/include'
> > +  $BASE/src/rtems/make/Templates/Makefile.lib
> '$BASE/rtems/5/share/rtems5/make/Templates'
> > +   $BASE/src/rtems/./install-sh -c -d '$BASE/rtems/5/make/custom'
> > +   /usr/bin/install -c -m 644 $BASE/src/rtems/make/custom/default.cfg
> > +  gmake[2]: Leaving directory '$BASE/build/b-erc32'
> > +Testing the BSP
> > +Since, we now have a BSP built and installed. We will test it by
> running a
> Delete "Since, " and capitalize "We"
> > +Hello world example. This example is already been built during the BSP
> build
> is -> has
> > +phase.
> > +We can run this using the simulator provided by RSB tools suite. The
> SPARC tools
> this -> "Hello World"
> > +suite comes with SIS simulator which can we used to run your
> executables on your
> "with the"
> "your executable" -> "RTEMS executables"
> > +host computer without the need for hardware.
> "hardware" -> "SPARC hardware"
> > +The ``Hello World`` executable can be found under
> +``$HOME/rtems/build/erc32/sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe``.
> > +To run the executable in the simulator we use the following command:
> > +  sparc-rtems5-sis
> > +The output will be the following:
> > +  sparc-rtems5-sis
> > +  SIS - SPARC/RISCV instruction simulator 2.20,  copyright Jiri Gaisler
> 2019
> > +  Bug-reports to jiri at gaisler.se
> > +  ERC32 emulation enabled
> > +  Loaded sparc-rtems5/c/erc32/testsuites/samples/hello.exe, entry
> 0x02000000
> > +  sis>
> > +This command will start the simulator and will load the executable in
> it. To run
> > +the exe, enter run in the simulator prompt ( `sis>` ). This will
> running the
> "will run"
> > +executable in the simulator and the following output will be produced.
> > +  sparc-rtems5-sis
> 2019
> 0x02000000
> > +  sis> run
> > +  *** BEGIN OF TEST HELLO WORLD ***
> > +  *** TEST VERSION: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
> > +  *** TEST STATE: EXPECTED-PASS
> > +  *** TEST BUILD: RTEMS_POSIX_API
> > +  *** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
> 83fa79314dd87c0a8c78fd642b2cea3138be8dd6, Newlib 3e24fbf6f)
> > +  Hello World
> > +  *** END OF TEST HELLO WORLD ***
> > +  *** FATAL ***
> > +  fatal source: 0 (INTERNAL_ERROR_CORE)
> > +  fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)
> > +  RTEMS version: 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807
> > +  RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB
> > +  executing thread ID: 0x08a010001
> > +  executing thread name: UI1
> > +  cpu 0 in error mode (tt = 0x101)
> > +    116401  02009ae0:  91d02000   ta  0x0
> > +Prove You Can Work On RTEMS
> > +Modify the hello world example to include a new different print
> statement.
> > +Something like "Hello from The Dark Side!". Then send us enough to
> prove to us
> > +that you did this. We want to know you can work with RTEMS.
> > +Create a patch of your changes and send it to :r:link:`devel` along
> with the
> > +screenshot of the output.
> Add a sentence like, "Use git-commit to create your patch, and make
> sure the git author information is correct."
> Maybe add a ref to the
> user/support/contrib.html#preparing-and-sending-patches
I have added a section below for creating patches. Should I still add a few
pointers here?
I am planning to add the git author information in that section. And add a
ref to
 user/support/contrib.html#preparing-and-sending-patches here.
> > +If you followed this guide, this hello world modification will likely
> need to be
> > +made to the file you'll have in
> ``$HOME/rtems/src/rtems/testsuites/samples/hello/init.c``.
> > +You can edit the file, commit your changes using git, and then run git
> > +format-patch master to generate a patch file.
> > +Creating Patch
> > +Once you have made the required changes in the ``init.c`` file. You
> will have to
> > +commit those changes. Before commiting the changes make sure you are
> not on the
> typo: committing
> > +master branch. This is to avoid merge conflicts. You can create and
> work on a
> > +separate local branch with the following git command.
> > +  git checkout -b gsoc
> > +This is will create a separate branch called `gsoc` and will switch you
> to it.
> delete 'is'
> > +Stage the file and commit using the following commands.
> > +  git add $HOME/rtems/src/rtems/testsuites/samples/hello/init.c
> > +  git commit -m "<YOUR-COMMIT-MESSAGE>"
> > +You can now create a patch file using ``git format-patch``.
> > +  git format-patch -1
> > +Sending Patches
> > +Once the patch file is created. You can now send it to :r:link:`devel`
> using
> > +``git send-email``. Please refer to `git send-email <
> https://git-scm.com/docs/git-send-email>`_
> > +for instructions on seting up the SMTP server and other options.
> typo: setting
> > +The following command will send the patch to the mailing list.
> > +  git send-email <YOUR-PATCH-FILE> --to devel at rtems.org
> > diff --git a/user/start/index.rst b/user/start/index.rst
> > index d6333f3..2d3ab2c 100644
> > --- a/user/start/index.rst
> > +++ b/user/start/index.rst
> > @@ -22,3 +22,4 @@ applications on top of RTEMS.
> >      bsp-build
> >      bsp-test
> >      app
> > +    gsoc
> > 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200322/5fde403d/attachment-0001.html>
