[PATCH 0/6] Proposes fixes for RTEMS Tester documentation page
clrrm at isep.ipp.pt clrrm at isep.ipp.pt
Sun Mar 22 16:17:37 UTC 2020
This set of patches proposes several fixes for RTEMS Tester
documentation. Namely:
- Text was reviewed and improved for clarity;
- References to 'sparc-rtems5-run' command and 'erc32-run' were removed
  from the documentation page. Now, the example uses 'erc32-sis' instead.
Further references to 'sparc-rtems5-run' are still in other parts of the
documentation (Sections 10.2 and 10.3) which also need to be updated in
the future.
In addition to this, I will send another patch in a different email
which removes 'erc32-run.ini' from 'rtems-tools' repo as this BSP
configuration uses 'sparc-rtems5-run'.
Cláudio Maia (6):
  user/tools/tester.rst: Cleans up text
  user/tools/tester.rst: Removes wrong reference to GDB break points
  user/tools/tester.rst: Clarifies the need of --rtems-tools in
    rtems-test command line
  user/tools/tester.rst: Rephrase last sentence
  user/tools/tester.rst: Removes example using 'sparc-rtems5-run'
  user/tools/tester.rst: Removes text references to 'erc32-run' and
    replaces the example with 'erc32-sis'
 user/tools/tester.rst | 191 ++++++++++++++++++++----------------------
 1 file changed, 93 insertions(+), 98 deletions(-)
2.17.1
