[PATCH 2/6] user/tools/tester.rst: Removes wrong reference to GDB break points
clrrm at isep.ipp.pt clrrm at isep.ipp.pt
Sun Mar 22 16:17:39 UTC 2020
 user/tools/tester.rst | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index 44263da..96e32ed 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -260,9 +260,6 @@ You can see your executable running in the first terminal.
 For more information on the sis simulator refer to this doc: https://gaisler.se/sis/sis.pdf
-The command ``r`` is used to debug set break points before issuing the GDB
-``run`` command.
 There are currently close to 500 separate tests and you can run them all with a
 single RTEMS Tester command.
2.17.1
