[PATCH 5/6] user/tools/tester.rst: Removes example using 'sparc-rtems5-run'
clrrm at isep.ipp.pt
Sun Mar 22 16:17:42 UTC 2020
user/tools/tester.rst | 14 +-------------
1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/user/tools/tester.rst b/user/tools/tester.rst
index a95651e..5147f3d 100644
--- a/user/tools/tester.rst
+++ b/user/tools/tester.rst
@@ -98,19 +98,7 @@ make finishes, all the tests will have been built.
Before running all the tests it is a good idea to run the ``hello`` test. The
``hello`` test is an RTEMS version of the classic "Hello World" example and
running it shows you have a working toolchain and build of RTEMS ready to run
-the tests. Using the run with the ERC32 BSP the command is:
-.. code-block:: none
- $ sparc-rtems5-run sparc-rtems5/c/erc32/testsuites/samples/hello/hello.exe
- *** BEGIN OF TEST HELLO WORLD ***
- Hello World
- *** END OF TEST HELLO WORLD ***
-The run command is the GDB simulator without the GDB part.
-Running the example using SIS:
+the tests. Running the example using SIS:
2.17.1
