[PATCH v8] tests for fenv.h functions
Eshan dhawan eshandhawan51 at gmail.com
Sun Mar 22 20:11:11 UTC 2020
 testsuites/psxtests/psxfenv01/init.c        | 105 +++++++++++++++-----
 testsuites/psxtests/psxfenv01/psxfenv01.doc |   9 +-
 testsuites/psxtests/psxfenv01/psxfenv01.scn |   4 -
 3 files changed, 85 insertions(+), 33 deletions(-)
diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
index cdb0fa596e..b088209d7f 100644
--- a/testsuites/psxtests/psxfenv01/init.c
+++ b/testsuites/psxtests/psxfenv01/init.c
@@ -46,11 +46,12 @@
 #include <rtems/test.h>
 #include <tmacros.h>
+#include <float.h>
 const char rtems_test_name[] = "PSXFENV 01";
 /* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument ignored);
+rtems_task Init( rtems_task_argument ignored );
 /* Test Function Begins */
@@ -62,40 +63,90 @@ rtems_task Init(rtems_task_argument ignored)
    * 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
-   * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
-   * 'fetestexcept()' functions are supported by the architecture.
+   * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
+   * fetestexcept() functions are supported by the architecture.
    * Hence their testcases can be wrapped under #ifdef and #endif.
   #ifdef FE_ALL_EXCEPT /* floating-point exceptions */
-    puts( "fesetenv(FE_DFL_ENV)." );
-    r = fesetenv(FE_DFL_ENV);
-    if (r)
-      printf("fesetenv ==> %d\n", r);
-    rtems_test_assert( r == 0 );
-    /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
-    puts( "feclearexcept(FE_ALL_EXCEPT)." );
-    r = feclearexcept(FE_ALL_EXCEPT);
-    if (r)
-      printf("feclearexcept ==> 0x%x\n", r);
-    r = fetestexcept( FE_ALL_EXCEPT );
-    if (r)
-      printf("fetestexcept ==> 0x%x\n", r);
-    /* Test 'FE_DIVBYZERO' */
-    puts( "Divide by zero and confirm fetestexcept()" );
+    r = fesetenv ( FE_DFL_ENV );
+    if ( r ) {
+      printf( "fesetenv ==> %d\n", r);
+    rtems_test_assert ( r == 0 );
+    /* Test feclearexcept() and fetestexcept() in one go. */
+    r = feclearexcept ( FE_ALL_EXCEPT );
+    if ( r ) {
+      printf( "feclearexcept ==> 0x%x\n", r );
+    r = fetestexcept ( FE_ALL_EXCEPT );
+    if ( r ) {
+      printf( "fetestexcept ==> 0x%x\n", r );
+    /* Test 'FE_DIVBYZERO'
+     *Divide by zero and confirm fetestexcept() */
     a = 0.0;
     b = 1.0;
     c = b/a;
     (void) c;
-    fegetexceptflag(&excepts,FE_ALL_EXCEPT);
+    /* Test fegetexceptflag() and fesetexceptflag() */
+    r = fegetexceptflag ( &excepts, FE_ALL_EXCEPT );
+    if ( r ) {
+      printf( "fegetexceptflag ==> 0x%x\n", r );
+    r = fesetexceptflag ( &excepts, FE_ALL_EXCEPT );
+    if ( r ) {
+      printf( "fesetexceptflag ==> 0x%x\n", r );
+    /* Test for fegetround() and fesetround()
+     * They have four main macros to be tested separated by ifdef
+     * Since not all architectures support them
+     * The test case gets and sets the rounding directions */
+#ifdef FE_TONEAREST
+    rtems_test_assert ( fegetround() == FE_TONEAREST );
+#endif
+#ifdef FE_TOWARDZERO
+  r = fesetround ( FE_TOWARDZERO );
+  if ( r ) {
+      printf( "fesetround ==> 0x%x\n", r );
+  rtems_test_assert ( fegetround() == FE_TOWARDZERO );
+#endif
+#ifdef FE_DOWNWARD
+  r = fesetround ( FE_DOWNWARD );
+  if ( r ) {
+  rtems_test_assert ( fegetround() == FE_DOWNWARD );
+#endif
+#ifdef FE_UPWARD
+  r = fesetround ( FE_UPWARD );
+  if ( r ) {
+  rtems_test_assert ( fegetround() == FE_UPWARD );
+#endif
+  r = fesetround ( FE_TONEAREST );
+  if ( r ) {
+#endif
 #ifdef FE_DIVBYZERO
-    r = feraiseexcept(FE_DIVBYZERO);
+    r = feraiseexcept ( FE_DIVBYZERO ) ;
     rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
 #endif
diff --git a/testsuites/psxtests/psxfenv01/psxfenv01.doc b/testsuites/psxtests/psxfenv01/psxfenv01.doc
index 3aa7757496..0238372013 100644
--- a/testsuites/psxtests/psxfenv01/psxfenv01.doc
+++ b/testsuites/psxtests/psxfenv01/psxfenv01.doc
@@ -1,4 +1,4 @@
-#  COPYRIGHT (c) 2019
+#  COPYRIGHT (c) 2019
 #  On-Line Applications Research Corporation (OAR).
 # SPDX-License-Identifier: BSD-2-Clause
@@ -12,8 +12,13 @@ Directives:
   fesetenv
   feclearexcept
   fetestexcept
-  texceptflag
   feraiseexcept
+  fesetexeptflag
+  fegetexeptflag
+  fegetround
+  fesetround
 Concepts:
diff --git a/testsuites/psxtests/psxfenv01/psxfenv01.scn b/testsuites/psxtests/psxfenv01/psxfenv01.scn
index 21395e6712..6ea3bc255e 100644
--- a/testsuites/psxtests/psxfenv01/psxfenv01.scn
+++ b/testsuites/psxtests/psxfenv01/psxfenv01.scn
@@ -1,7 +1,3 @@
 *** BEGIN OF TEST PSXFENV 01 ***
-fesetenv(FE_DFL_ENV).
-feclearexcept(FE_ALL_EXCEPT).
-Divide by zero and confirm fetestexcept()
 *** END OF TEST PSXFENV 01 ***
2.17.1
