possible sources for porting sockatmark() of sys/socket.h
Gedare Bloom
gedare at rtems.org
Mon Mar 23 01:21:46 UTC 2020
On Sun, Mar 22, 2020 at 1:22 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> confstr() from unistd.h also shows not supported in the compliance status but it has some kind of supported in newlib(libc/sys/linux)
sys/linux doesn't work on rtems. that is only for linux-specific newlib builds
> it also needs to be updated in the compliance status I think
> On Mon, Mar 23, 2020 at 12:37 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> https://lists.rtems.org/pipermail/devel/2020-March/058569.html
>> On Mon, Mar 23, 2020 at 12:35 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>> On Mon, Mar 23, 2020 at 12:27 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> On Sun, Mar 22, 2020, 1:55 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>>>> It's present there.
>>>>> I hadn't checked there.
>>>> Does that mean the spreadsheet I uploaded yesterday needs updating again?
>>> yes , the spreadsheet shows not supported.
>>> also, I have sent another mail related to this
>>> for wordexp.h
>>>> Is there a ticket to close?
>>> No the ticket was closed earlier
>>> I missed that
>>>> Finding something got added without the tracking update is a good outcome
>>>>> On Mon, Mar 23, 2020 at 12:19 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>>> On Sun, Mar 22, 2020, 1:37 PM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>>>>>>> I have identifies 2 main sources to port sockatmark().
>>>>>>> NetBSD source:
>>>>>>> https://github.com/NetBSD/src/blob/trunk/lib/libc/net/sockatmark.c
>>>>>>> FreeBSD Source :
>>>>>>> https://github.com/lattera/freebsd/blob/master/lib/libc/net/sockatmark.c
>>>>>>> musl has a same implementation as in FreeBSD
>>>>>>> which one would be better to follow.
>>>>>> This has to be in sync with rtems-libbsd and may already be there. Please check if it is there. Just closing a ticket and updating the spreadsheet is q food result. :)
Should it also be available in "legacy" networking stack? Or do we let
that bitrot / maintain only?
>>>>>>> thanks
>>>>>>> -Eshan
> devel mailing list
> devel at rtems.org
