[PATCH v3 3/3] i386: Port to RTEMS
Mon Mar 23 09:58:30 UTC 2020
On 23/03/2020 09:06, Jan Sommer wrote:
> @@ -4597,7 +4599,12 @@ iflib_device_register(device_t dev, void *sc, if_shared_ctx_t sctx, if_ctx_t *ct
>   	/* Set up cpu set.  If it fails, use the set of all CPUs. */
>   	if (bus_get_cpus(dev, INTR_CPUS, sizeof(ctx->ifc_cpus), &ctx->ifc_cpus) != 0) {
>   		device_printf(dev, "Unable to fetch CPU list\n");
> +#ifndef __rtems__
>   		CPU_COPY(&all_cpus, &ctx->ifc_cpus);
> +#else /* __rtems__ */
> +		cpuset_t cpus = {all_cpus};
> +		CPU_COPY(&cpus, &ctx->ifc_cpus);
> +#endif /* __rtems__ */
>   	MPASS(CPU_COUNT(&ctx->ifc_cpus) > 0);
What is the reason for this change?
Could you please move the changes in non-x86 specific files to a
separate commit. Especially the <sys/callout.h> is an important header
file used across all architectures.
