[PATCH v3] bsp/beagle: Update console to new Termios API.
G S Niteesh Babu
niteesh.gs at gmail.com
Mon Mar 23 10:28:09 UTC 2020
This patch updates the console driver to new Termios API.
Update #3034
bsps/arm/beagle/console/console-config.c | 117 +++++++++++++----------
c/src/lib/libbsp/arm/beagle/Makefile.am | 4 +-
2 files changed, 69 insertions(+), 52 deletions(-)
diff --git a/bsps/arm/beagle/console/console-config.c b/bsps/arm/beagle/console/console-config.c
index 78af5f6a93..b2246571f8 100644
--- a/bsps/arm/beagle/console/console-config.c
+++ b/bsps/arm/beagle/console/console-config.c
@@ -21,12 +21,15 @@
* Modified by Ben Gras <beng at shrike-systems.com> to make
* interrupt-driven uart i/o work for beagleboards; beaglebone support added.
+ * Modified by Niteesh Babu G S <niteesh.gs at gmail.com>
+ * Update console to new termios API.
-#include <libchip/serial.h>
#include <libchip/ns16550.h>
#include <rtems/bspIo.h>
+#include <rtems/console.h>
#include <bsp.h>
#include <bsp/irq.h>
@@ -41,6 +44,8 @@
#define TX_FIFO_E (1<<5)
#define RX_FIFO_E (1<<0)
+#define BEAGLE_UART0 "/dev/ttyS0"
static uint8_t beagle_uart_get_register(uintptr_t addr, uint8_t i)
uint8_t v;
@@ -65,77 +70,91 @@ static void beagle_uart_set_register(uintptr_t addr, uint8_t i, uint8_t val)
reg [i] = val;
-console_tbl Console_Configuration_Ports [] = {
- .sDeviceName = "/dev/ttyS0",
- .deviceType = SERIAL_NS16550,
-#if CONSOLE_POLLED /* option to facilitate running the tests */
- .pDeviceFns = &ns16550_fns_polled,
-#else
- .pDeviceFns = &ns16550_fns,
-#endif
- .ulMargin = 16,
- .ulHysteresis = 8,
- .pDeviceParams = (void *) CONSOLE_BAUD,
- .ulCtrlPort1 = BSP_CONSOLE_UART_BASE,
- .ulDataPort = BSP_CONSOLE_UART_BASE,
- .ulIntVector = BSP_CONSOLE_UART_IRQ,
- .getRegister = beagle_uart_get_register,
- .setRegister = beagle_uart_set_register,
- .ulClock = UART_CLOCK, /* 48MHz base clock */
-unsigned long Console_Configuration_Count = 1;
-static int init_needed = 1; // don't rely on bss being 0
+static ns16550_context uart_context;
+static void uart_write_polled( char c );
static void beagle_console_init(void)
- if(init_needed) {
- const uint32_t div = UART_CLOCK / 16 / CONSOLE_BAUD;
- CONSOLE_SYSC = 2;
- while ((CONSOLE_SYSS & 1) == 0)
- if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) == CONSOLE_LSR_THRE) {
- CONSOLE_LCR = 0x83;
- CONSOLE_DLL = div;
- CONSOLE_DLM = (div >> 8) & 0xff;
- CONSOLE_LCR = 0x03;
- CONSOLE_ACR = 0x00;
+ ns16550_context *ctx;
+ static bool initialized = false;
- while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
+ if ( initialized ) {
+ return ;
- CONSOLE_LCR = 0x80 | 0x03;
- CONSOLE_DLL = 0x00;
- CONSOLE_DLM = 0x00;
- CONSOLE_MCR = 0x03;
- CONSOLE_FCR = 0x07;
+ * Don't rely on BSS being zeroed
+ memset(&uart_context, 0, sizeof(uart_context));
+ ctx = &uart_context;
+ ctx->port = BSP_CONSOLE_UART_BASE;
+ ctx->irq = BSP_CONSOLE_UART_IRQ;
+ ctx->set_reg = beagle_uart_set_register;
+ ctx->get_reg = beagle_uart_get_register;
+ ctx->initial_baud = CONSOLE_BAUD;
+ ctx->clock = UART_CLOCK;
+ const uint32_t div = UART_CLOCK / 16 / CONSOLE_BAUD;
+ CONSOLE_SYSC = 2;
+ while ((CONSOLE_SYSS & 1) == 0)
+ if ((CONSOLE_LSR & (CONSOLE_LSR_THRE | CONSOLE_LSR_TEMT)) == CONSOLE_LSR_THRE) {
CONSOLE_LCR = 0x83;
CONSOLE_DLL = div;
CONSOLE_LCR = 0x03;
CONSOLE_ACR = 0x00;
- init_needed = 0;
+ while ((CONSOLE_LSR & CONSOLE_LSR_TEMT) == 0)
+ CONSOLE_LCR = 0x80 | 0x03;
+ CONSOLE_DLL = 0x00;
+ CONSOLE_DLM = 0x00;
+ CONSOLE_LCR = 0x03;
+ CONSOLE_MCR = 0x03;
+ CONSOLE_FCR = 0x07;
+ CONSOLE_LCR = 0x83;
+ CONSOLE_DLL = div;
+ CONSOLE_DLM = (div >> 8) & 0xff;
+ CONSOLE_ACR = 0x00;
+ BSP_output_char = uart_write_polled;
#define CONSOLE_THR8 (*(volatile uint8_t *) (BSP_CONSOLE_UART_BASE + 0x00))
- if(init_needed) beagle_console_init();
while( ( CONSOLE_LSR & TX_FIFO_E ) == 0 )
CONSOLE_THR8 = c;
+rtems_status_code console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_termios_initialize();
+ beagle_console_init();
+ rtems_termios_device_install(
+ BEAGLE_UART0,
+ &ns16550_handler_polled,
+ NULL,
+ &uart_context.base
+ return RTEMS_SUCCESSFUL;
static void _BSP_put_char( char c ) {
- uart_write_polled( c );
+ uart_write_polled( c );
static int _BSP_get_char(void)
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index e37472373c..1cd9920b2f 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -62,9 +62,7 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/irq/irq.c
# Console
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
-librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/legacy-console-select.c
+librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termios.c
librtemsbsp_a_SOURCES += ../../../../../../bsps/arm/beagle/console/console-config.c
# I2C
2.17.1
