AW: [PATCH v3 3/3] i386: Port to RTEMS
Mon Mar 23 13:20:24 UTC 2020
On 23/03/2020 13:50, Jan.Sommer at dlr.de wrote:
>> -----Ursprüngliche Nachricht-----
>> Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
>> Gesendet: Montag, 23. März 2020 10:59
>> An: Sommer, Jan;devel at rtems.org
>> Betreff: Re: [PATCH v3 3/3] i386: Port to RTEMS
>> On 23/03/2020 09:06, Jan Sommer wrote:
>>> @@ -4597,7 +4599,12 @@ iflib_device_register(device_t dev, void *sc,
>> if_shared_ctx_t sctx, if_ctx_t *ct
>>>    	/* Set up cpu set.  If it fails, use the set of all CPUs. */
>>>    	if (bus_get_cpus(dev, INTR_CPUS, sizeof(ctx->ifc_cpus), &ctx-
>>> ifc_cpus) != 0) {
>>>    		device_printf(dev, "Unable to fetch CPU list\n");
>>> +#ifndef __rtems__
>>>    		CPU_COPY(&all_cpus, &ctx->ifc_cpus);
>>> +#else /* __rtems__ */
>>> +		cpuset_t cpus = {all_cpus};
>>> +		CPU_COPY(&cpus, &ctx->ifc_cpus);
>>> +#endif /* __rtems__ */
>>>    	MPASS(CPU_COUNT(&ctx->ifc_cpus) > 0);
>> What is the reason for this change?
> For RTEMS the all_cpus variable has been replaced in freebsd/sys/sys/smp.h to " #define all_cpus 1U".
> The additional variable is there because CPU_COPY requires an address.
Ok, problems like this are an indication that you try to use a feature
which is not really supported. I would first try to understand what the
purpose of the ifc_cpus is. Maybe this stuff could be disabled completely.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200323/6689de34/attachment.html>
