[rtems-littlevgl PATCH v2 1/2] Add README
Vijay Kumar Banerjee vijay at rtems.org
Tue Mar 24 19:08:58 UTC 2020
 README.md | 47 +++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 47 insertions(+)
 create mode 100644 README.md
diff --git a/README.md b/README.md
new file mode 100644
index 0000000..d0e7b02
--- /dev/null
+++ b/README.md
@@ -0,0 +1,47 @@
+RTEMS LittlevGL
+Welcome to RTEMS LittlevGL (lvgl). This package builds the lvgl library using
+waf with the required settings for running it with rtems. The lvgl drivers are
+adapted to the BSD framebuffer and hence requires the latest rtems-libbsd build.
+About LittlevGL
+LittlevGL is a lightweight graphics library for embedded GUI applications. It
+can be configured using the `lv_conf.h` and the `lv_drv_conf.h` files that are
+in the top of the rtems-littlevgl directory.
+The documentation is available at:
+https://docs.littlevgl.com/en/html/index.html
+Building and installing rtems-littlevgl
+git clone git://git.rtems.org/packages/rtems-littlevgl.git
+git submodule update
+./waf configure --prefix=/path/to/rtems/5
+./waf build install
+Writing embedded GUI app using rtems-littlevgl
+The rtems-examples repository has a sample lvgl hello world application that can +be followed for reference on how to write and build an application with lvgl.
+The sample app can be found here:
+https://git.rtems.org/rtems-examples/tree/lvgl/hello/test.c
+Where to discuss questions and ideas?
+The preferred way of carrying out any discussions or questions is to reach out
+to the users mailing list users at rtems.org or the devel mailing list
+devel at rtems.org for more detailed discussions.
+In any discussions related to rtems-littlevgl, the maintainers can be CC'd by
+their respective id's given below:
+Christian Mauderer (christian.mauderer at embedded-brains.de)
+Vijay Kumar Banerjee (vijay at rtems.org)
2.21.1
