discussion related to implementation of File descriptor functions in RTEMS
Eshan Dhawan eshandhawan51 at gmail.com
Wed Mar 25 21:09:15 UTC 2020
On Thu, Mar 26, 2020 at 1:03 AM Joel Sherrill <joel at rtems.org> wrote:
> On Wed, Mar 25, 2020 at 12:17 AM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> On Wed, Mar 25, 2020 at 4:01 AM Joel Sherrill <joel at rtems.org> wrote:
>>> On Tue, Mar 24, 2020 at 4:57 PM Eshan Dhawan <eshandhawan51 at gmail.com>
>>> wrote:
>>>> Hello everyone,
>>>> As @Vaibhav Gupta <vaibhav.varodek at gmail.com> suggested I have also
>>>> added adding file descriptor functions to my GSOC project.
>>>> I went through the mailing list archives for more information.
>>>> RTEMS as its own file descriptor so the functions need to be
>>>> implemented from scratch.
>>>> I wanted to get more information related to it.
>>> What's the set of functions you are proposing for those not tracking
>>> your draft proposal?
>> Link:
>> https://docs.google.com/document/d/1n-JOFUbFn6V1kViAGWsEGbVHL9MxlMyKP0BbZhEA1Rs/edit?usp=sharing
>> I haven't searched about the functions in the list yet. The list was made
>> by Vaibhav, last year and he told me that it could be added to proposal
>> this year as well.
>> I read the archives that these need to be written from scratch.
> Maybe not. I found at least this implementation of renameat() which was
> implemented on top of existing calls:
> https://github.com/lattera/freebsd/blob/master/contrib/openbsm/bin/auditdistd/renameat.h
> It should be in a C file but that shows it can be done. That directory has
> a lot of these methods.
> NOTE: That list has fstat() while I am sure it should be fstatat.
> The list has fstatat as well.
I will recheck the list and will run a search to confirm that list doesn't
contain any function that has been already implemented  :)
> I would move these up the list since they look easy to port from that
> source. Convert them from .h to .c, and we can discuss adding them to
> newlib.
> @Aditya Upadhyay <aadit0402 at gmail.com> told that need to be added to
RTEMS libbsd
> --joel
>>>> thanks
>>>> -Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200326/53c061b3/attachment.html>
