Release sources
Gedare Bloom
gedare at rtems.org
Thu Mar 26 16:04:22 UTC 2020
On Thu, Mar 26, 2020 at 9:40 AM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Mar 26, 2020 at 10:17 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Mar 26, 2020 at 7:28 AM Joel Sherrill <joel at rtems.org> wrote:
>> > On Thu, Mar 26, 2020 at 2:26 AM Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> >> On 26/03/2020 07:54, Chris Johns wrote:
>> >> On 2020-03-20 14:57, Chris Johns wrote:
>> >> Only having sources in `sources` is a change from how RTEMS has been released in
>> >> the past so I feel this needs to be discussed and approved before I make any
>> >> changes.
>> >> I will place all source in `sources`.
>> >> Sorry I missed this email. Placing the sources in a directory is an improvement from my point of view.
>> +1
>> > Does this mean you will end up with one source tarball with every repo in it?
>> A release contains basically a snapshot of all source code that goes
>> into it, including tools. The 'sources' directory will contain all of
>> those snapshots, each one a tarball of the respective source (e.g.,
>> automake-x.y.z, rtems-x.y, etc.).
>> Look at the 4.11.3 release for an example of how it was being done:
>> https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.3/
>> See that there is a sources directory, but that we also put "our"
>> source in the top-level. Chris' plan is to also put the rtems-*.tar.xz
>> underneath sources/
> Hmm.. Why would we mix RTEMS originated source packages with
> third party source and patches. This directory is already quite lengthy.
> I must have missed the clear statement of what the advantage is.
The advantage is that all the source that belongs to the release is
consolidated. all rtems packages are prepended by rtems- so they are
still easily identifiable in the sources subdirectory.
Ideally, the readme will simply direct the user to run the
script/command necessary to build things :) I think this is simpler,
and users will still be able to find specific sources as they need by
looking in one place.
>> (I discussed with him briefly before, and am in favor of this
>> approach, but held my vote :))
>> > --joel
>> >> _______________________________________________
>> >> devel mailing list
>> >> devel at rtems.org
>> >> http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
