[PATCH v11] tests for fenv.h functions
Eshan dhawan
eshandhawan51 at gmail.com
Fri Mar 27 17:04:17 UTC 2020
testsuites/psxtests/psxfenv01/init.c | 88 ++++++++++++++++-----
testsuites/psxtests/psxfenv01/psxfenv01.doc | 9 ++-
testsuites/psxtests/psxfenv01/psxfenv01.scn | 4 -
3 files changed, 76 insertions(+), 25 deletions(-)
diff --git a/testsuites/psxtests/psxfenv01/init.c b/testsuites/psxtests/psxfenv01/init.c
index cdb0fa596e..cfa31d6a16 100644
--- a/testsuites/psxtests/psxfenv01/init.c
+++ b/testsuites/psxtests/psxfenv01/init.c
@@ -6,6 +6,7 @@
* SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Eshan Dhawan
* Copyright (C) 2019 Vaibhav Gupta
@@ -46,11 +47,12 @@
#include <rtems/test.h>
#include <tmacros.h>
+#include <float.h>
const char rtems_test_name[] = "PSXFENV 01";
/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument ignored);
+rtems_task Init( rtems_task_argument ignored );
/* Test Function Begins */
@@ -62,40 +64,90 @@ rtems_task Init(rtems_task_argument ignored)
* 'FE_ALL_EXCEPT' will be defined only when 'feclearexcept()',
- * 'fegetexceptflag()', 'feraiseexcept()', 'fesetexceptflag()' and
- * 'fetestexcept()' functions are supported by the architecture.
+ * fegetexceptflag() , feraiseexcept(), fesetexceptflag() and
+ * fetestexcept() functions are supported by the architecture.
* Hence their testcases can be wrapped under #ifdef and #endif.
#ifdef FE_ALL_EXCEPT /* floating-point exceptions */
- puts( "fesetenv(FE_DFL_ENV)." );
- r = fesetenv(FE_DFL_ENV);
- if (r)
- printf("fesetenv ==> %d\n", r);
+ r = fesetenv( FE_DFL_ENV );
+ if ( r ) {
+ printf( "fesetenv ==> %d\n", r);
rtems_test_assert( r == 0 );
- /* Test 'feclearexcept()' and 'fetestexcept()' in one go. */
- puts( "feclearexcept(FE_ALL_EXCEPT)." );
- r = feclearexcept(FE_ALL_EXCEPT);
- if (r)
- printf("feclearexcept ==> 0x%x\n", r);
+ /* Test feclearexcept() and fetestexcept() in one go. */
+ r = feclearexcept( FE_ALL_EXCEPT );
+ if ( r ) {
+ printf( "feclearexcept ==> 0x%x\n", r );
r = fetestexcept( FE_ALL_EXCEPT );
- if (r)
- printf("fetestexcept ==> 0x%x\n", r);
+ if ( r ) {
+ printf( "fetestexcept ==> 0x%x\n", r );
- /* Test 'FE_DIVBYZERO' */
- puts( "Divide by zero and confirm fetestexcept()" );
+ /* Test 'FE_DIVBYZERO'
+ *Divide by zero and confirm fetestexcept() */
a = 0.0;
b = 1.0;
c = b/a;
(void) c;
+ /* Test fegetexceptflag() and fesetexceptflag() */
+ r = fegetexceptflag( &excepts, FE_ALL_EXCEPT );
+ if ( r ) {
+ printf( "fegetexceptflag ==> 0x%x\n", r );
+ rtems_test_assert( r == 0 );
- fegetexceptflag(&excepts,FE_ALL_EXCEPT);
+ r = fesetexceptflag( &excepts, FE_ALL_EXCEPT );
+ if ( r ) {
+ printf( "fesetexceptflag ==> 0x%x\n", r );
+ /* Test for fegetround() and fesetround()
+ * They have four main macros to be tested separated by ifdef
+ * Since not all architectures support them
+ * The test case gets and sets the rounding directions */
+#ifdef FE_TONEAREST
+ rtems_test_assert( fegetround() == FE_TONEAREST );
+#endif
+#ifdef FE_TOWARDZERO
+ r = fesetround( FE_TOWARDZERO );
+ if ( r ) {
+ printf( "fesetround ==> 0x%x\n", r );
+ rtems_test_assert( fegetround() == FE_TOWARDZERO );
+#endif
+#ifdef FE_DOWNWARD
+ r = fesetround( FE_DOWNWARD );
+ if ( r ) {
+ rtems_test_assert( fegetround() == FE_DOWNWARD );
+#endif
+#ifdef FE_UPWARD
+ r = fesetround( FE_UPWARD );
+ if ( r ) {
+ rtems_test_assert( fegetround() == FE_UPWARD );
+#endif
+ r = fesetround( FE_TONEAREST );
+ if ( r ) {
+#endif
#ifdef FE_DIVBYZERO
- r = feraiseexcept(FE_DIVBYZERO);
+ r = feraiseexcept( FE_DIVBYZERO ) ;
rtems_test_assert( fetestexcept( FE_DIVBYZERO ) );
#endif
diff --git a/testsuites/psxtests/psxfenv01/psxfenv01.doc b/testsuites/psxtests/psxfenv01/psxfenv01.doc
index 3aa7757496..52d9fd19c7 100644
--- a/testsuites/psxtests/psxfenv01/psxfenv01.doc
+++ b/testsuites/psxtests/psxfenv01/psxfenv01.doc
@@ -1,4 +1,4 @@
-# COPYRIGHT (c) 2019
+# COPYRIGHT (c) 2019
# On-Line Applications Research Corporation (OAR).
# SPDX-License-Identifier: BSD-2-Clause
@@ -12,9 +12,12 @@ Directives:
fesetenv
feclearexcept
fetestexcept
- texceptflag
feraiseexcept
+ fesetexeptflag
+ fegetexeptflag
+ fegetround
+ fesetround
Concepts:
+ This test exercises the fenv.h methods.
diff --git a/testsuites/psxtests/psxfenv01/psxfenv01.scn b/testsuites/psxtests/psxfenv01/psxfenv01.scn
index 21395e6712..6ea3bc255e 100644
--- a/testsuites/psxtests/psxfenv01/psxfenv01.scn
+++ b/testsuites/psxtests/psxfenv01/psxfenv01.scn
@@ -1,7 +1,3 @@
*** BEGIN OF TEST PSXFENV 01 ***
-fesetenv(FE_DFL_ENV).
-feclearexcept(FE_ALL_EXCEPT).
-Divide by zero and confirm fetestexcept()
*** END OF TEST PSXFENV 01 ***
2.17.1
