RISC-V BSP Test Results
Joel Sherrill
joel at rtems.org
Fri Mar 27 17:49:12 UTC 2020
Hi
I wanted to pass along that Spike appears to be working now from the RSB.
Test results are in the build archive show that 5 or 7 fail on sis but the
other BSPs tend to have 20-24 failures with some timeouts and invalids. No
idea why. It would be appreciated if anyone who knows the RISC-V
could see if these are reasonable.
- [rtems-test] riscv/griscv: RTEMS_POSIX_API: Passed:577 Failed:5
Timeout:0 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012304.html> *joel
at rtems.org <http://rtems.org>*
- [rtems-test] riscv/griscv: RTEMS_DEBUG, RTEMS_POSIX_API: Passed:575
Failed:7 Timeout:0 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012305.html> *joel
- [rtems-test] riscv32/rv32iac: RTEMS_POSIX_API: Passed:545 Failed:20
Timeout:17 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012306.html> *joel
- [rtems-test] riscv32/rv32imac: RTEMS_POSIX_API: Passed:546 Failed:23
Timeout:13 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012307.html> *joel
- [rtems-test] riscv32/rv32imafc: RTEMS_POSIX_API: Passed:545 Failed:23
Timeout:14 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012308.html> *joel
- [rtems-test] riscv32/rv32imafdc: RTEMS_POSIX_API: Passed:544 Failed:24
<https://lists.rtems.org/pipermail/build/2020-March/012310.html> *joel
- [rtems-test] riscv32/rv32imafd: RTEMS_POSIX_API: Passed:542 Failed:22
Timeout:18 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012311.html> *joel
- [rtems-test] riscv32/rv32im: RTEMS_POSIX_API: Passed:544 Failed:21
<https://lists.rtems.org/pipermail/build/2020-March/012312.html> *joel
- [rtems-test] riscv32/rv32i: RTEMS_POSIX_API: Passed:543 Failed:20
Timeout:17 Invalid:2 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012313.html> *joel
- [rtems-test] riscv64/rv64imac: RTEMS_POSIX_API: Passed:548 Failed:22
Timeout:12 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012315.html> *joel
- [rtems-test] riscv64/rv64imac: RTEMS_POSIX_API: Passed:549 Failed:22
Timeout:11 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012316.html> *joel
- [rtems-test] riscv64/rv64imafdc_medany: RTEMS_POSIX_API: Passed:549
Failed:21 Timeout:12 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012317.html> *joel
- [rtems-test] riscv64/rv64imafdc: RTEMS_POSIX_API: Passed:549 Failed:21
<https://lists.rtems.org/pipermail/build/2020-March/012318.html> *joel
- [rtems-test] riscv64/rv64imafd: RTEMS_POSIX_API: Passed:552 Failed:20
Timeout:10 Invalid:0 Wrong:0
<https://lists.rtems.org/pipermail/build/2020-March/012320.html> *joel
- [rtems-test] riscv64/rv64imafd: RTEMS_POSIX_API: Passed:552 Failed:19
<https://lists.rtems.org/pipermail/build/2020-March/012321.html> *joel
If anyone reads this far, I want to point out that there are ~1450 posts to
the build@ mailing list this month!!!
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200327/ce4161f1/attachment-0001.html>
