[PATCH 1/2] bsp/raspberrypi: Fix build warnings.
G S Niteesh Babu
niteesh.gs at gmail.com
Sat Mar 28 10:50:06 UTC 2020
1) _Memory_Initialize makes pointer from integer w
ithout a cast.
2) printf format error, expects %u but %lu provided.
bsps/arm/raspberrypi/irq/irq.c | 2 +-
bsps/arm/raspberrypi/start/bspstarthooks.c | 2 ++
2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/bsps/arm/raspberrypi/irq/irq.c b/bsps/arm/raspberrypi/irq/irq.c
index 9e1bcfc1bc..73dcad298f 100644
--- a/bsps/arm/raspberrypi/irq/irq.c
+++ b/bsps/arm/raspberrypi/irq/irq.c
@@ -157,7 +157,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector)
void bsp_interrupt_handler_default(rtems_vector_number vector)
- printk("spurious interrupt: %lu\n", vector);
+ printk("spurious interrupt: %u\n", vector);
rtems_status_code bsp_interrupt_facility_initialize(void)
diff --git a/bsps/arm/raspberrypi/start/bspstarthooks.c b/bsps/arm/raspberrypi/start/bspstarthooks.c
index fd6aa53059..eb6546db1c 100644
--- a/bsps/arm/raspberrypi/start/bspstarthooks.c
+++ b/bsps/arm/raspberrypi/start/bspstarthooks.c
@@ -184,7 +184,9 @@ static void bsp_memory_initialize(void)
_Memory_Initialize(
&_Memory_Areas[0],
+ (void *)
raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].begin,
+ (void *)
raspberrypi_mmu_config_table[ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX].end
2.17.1
