[PATCH] c-user: New template for initializer config opts
Mon Mar 30 09:28:17 UTC 2020
Try to bring all descriptions up to date.  Add cross-references to
several options.  Clarify configuration value constraints.
Close #3901.
 c-user/config/bsp-related.rst       | 87 ++++++++++++++++++++++---------------
 c-user/config/classic-init-task.rst | 21 +++++----
 c-user/config/device-driver.rst     | 56 ++++++++++++------------
 c-user/config/general.rst           | 22 +++++-----
 c-user/config/idle-task.rst         | 25 ++++++-----
 c-user/config/mpci.rst              | 17 ++++----
 c-user/config/posix-init-thread.rst | 21 +++++----
 c-user/config/task-stack-alloc.rst  | 67 ++++++++++++++--------------
 8 files changed, 171 insertions(+), 145 deletions(-)
diff --git a/c-user/config/bsp-related.rst b/c-user/config/bsp-related.rst
index 12d437f..88f2c26 100644
--- a/c-user/config/bsp-related.rst
+++ b/c-user/config/bsp-related.rst
@@ -20,24 +20,30 @@ BSP_IDLE_TASK_BODY
 CONSTANT:
     ``BSP_IDLE_TASK_BODY``
-DATA TYPE:
-    Function pointer.
-RANGE:
-    Undefined or valid function pointer.
+OPTION TYPE:
+    This configuration option is an initializer define.
 DEFAULT VALUE:
-    This option is BSP specific.
+    The default value is BSP-specific.
+VALUE CONSTRAINTS:
+    The value of this configuration option must be defined to a valid function
+    pointer of the type ``void *( *idle_body )( uintptr_t )``.
 DESCRIPTION:
-    If ``BSP_IDLE_TASK_BODY`` is defined by the BSP and
-    ``CONFIGURE_IDLE_TASK_BODY`` is not defined by the application, then this
-    BSP specific idle task body will be used.
+    If
+    * this configuration option is defined by the BSP
+    * and :ref:`CONFIGURE_DISABLE_BSP_SETTINGS` is undefined,
+    then the value of this configuration option defines the default value of
+    :ref:`CONFIGURE_IDLE_TASK_BODY`.
 NOTES:
     As it has knowledge of the specific CPU model, system controller logic, and
-    peripheral buses, a BSP specific IDLE task may be capable of turning
-    components off to save power during extended periods of no task activity
+    peripheral buses, a BSP-specific IDLE task may be capable of turning
+    components off to save power during extended periods of no task activity.
 .. index:: BSP_IDLE_TASK_STACK_SIZE
@@ -89,22 +95,29 @@ BSP_INITIAL_EXTENSION
 CONSTANT:
     ``BSP_INITIAL_EXTENSION``
-DATA TYPE:
-    List of user extension initializers (``rtems_extensions_table``).
-RANGE:
-    Undefined or a list of user extension initializers.
+OPTION TYPE:
 DEFAULT VALUE:
+VALUE CONSTRAINTS:
+    The value of this configuration option must be a list of initializers for
+    structures of type :c:type:`rtems_extensions_table`.
 DESCRIPTION:
-    If ``BSP_INITIAL_EXTENSION`` is defined by the BSP, then this BSP specific
-    initial extension will be placed as the last entry in the initial extension
-    table.
+    If
+    then the value of this configuration option is used to initialize the table
+    of initial user extensions.
 NOTES:
-    None.
+    The value of this configuration option is placed after the entries of all
+    other initial user extensions.
 .. index:: BSP_INTERRUPT_STACK_SIZE
@@ -156,26 +169,30 @@ CONFIGURE_BSP_PREREQUISITE_DRIVERS
 CONSTANT:
     ``CONFIGURE_BSP_PREREQUISITE_DRIVERS``
-DATA TYPE:
-    List of device driver initializers (``rtems_driver_address_table``).
-RANGE:
-    Undefined or array of device drivers.
+OPTION TYPE:
 DEFAULT VALUE:
+VALUE CONSTRAINTS:
 DESCRIPTION:
-    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is defined if the BSP has device
-    drivers it needs to include in the Device Driver Table.  This should be
-    defined to the set of device driver entries that will be placed in the
-    table at the *FRONT* of the Device Driver Table and initialized before any
-    other drivers *INCLUDING* any application prerequisite drivers.
+    If
 NOTES:
-    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is typically used by BSPs to
-    configure common infrastructure such as bus controllers or probe for
-    devices.
+    The value of this configuration option is placed before the entries of all
+    other initial user extensions (including
+    :ref:`CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS`).
 .. index:: CONFIGURE_DISABLE_BSP_SETTINGS
diff --git a/c-user/config/classic-init-task.rst b/c-user/config/classic-init-task.rst
index 8f699ee..9987293 100644
--- a/c-user/config/classic-init-task.rst
+++ b/c-user/config/classic-init-task.rst
@@ -71,23 +71,22 @@ CONFIGURE_INIT_TASK_ENTRY_POINT
 CONSTANT:
     ``CONFIGURE_INIT_TASK_ENTRY_POINT``
-DATA TYPE:
-    Task entry function pointer (``rtems_task_entry``).
-RANGE:
-    Valid task entry function pointer.
+OPTION TYPE:
 DEFAULT VALUE:
     The default value is ``Init``.
+VALUE CONSTRAINTS:
+    pointer of the type ``void ( *entry_point )( rtems_task_argument )``.
 DESCRIPTION:
-    ``CONFIGURE_INIT_TASK_ENTRY_POINT`` is the entry point (a.k.a. function
-    name) of the single initialization task defined by the Classic API
-    Initialization Tasks Table.
+    The value of this configuration option initializes the entry point of the
+    Classic API initialization task.
 NOTES:
-    The user must implement the function ``Init`` or the function name provided
-    in this configuration parameter.
+    The user must implement the function referenced by this configuration option.
 .. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
@@ -228,7 +227,7 @@ NOTES:
     The application must define exactly one of the following configuration
     options
-    * :ref:`CONFIGURE_RTEMS_INIT_TASKS_TABLE`,
+    * `CONFIGURE_RTEMS_INIT_TASKS_TABLE`,
     * :ref:`CONFIGURE_POSIX_INIT_THREAD_TABLE`, or
diff --git a/c-user/config/device-driver.rst b/c-user/config/device-driver.rst
index 367573e..c229c99 100644
--- a/c-user/config/device-driver.rst
+++ b/c-user/config/device-driver.rst
@@ -54,23 +54,26 @@ CONFIGURE_APPLICATION_EXTRA_DRIVERS
 CONSTANT:
     ``CONFIGURE_APPLICATION_EXTRA_DRIVERS``
-DATA TYPE:
-    device driver entry structures
-RANGE:
-    Undefined or set of device driver entry structures
+OPTION TYPE:
 DEFAULT VALUE:
-    This is not defined by default.
+    The default value is the empty list.
+VALUE CONSTRAINTS:
+    structures of type :c:type:`rtems_driver_address_table`.
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_EXTRA_DRIVERS`` is defined if the application has
-    device drivers it needs to include in the Device Driver Table.  This should
-    be defined to the set of device driver entries that will be placed in the
-    table at the *END* of the Device Driver Table.
+    The value of this configuration option is used to initialize the Device
+    Driver Table.
 NOTES:
-    None.
+    The value of this configuration option is placed after the entries of other
+    device driver configuration options.
+    See :ref:`CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS` for an alternative
+    placement of application device driver initializers.
 .. index:: CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
@@ -445,28 +448,27 @@ CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
 CONSTANT:
     ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS``
-DATA TYPE:
-RANGE:
+OPTION TYPE:
 DEFAULT VALUE:
+VALUE CONSTRAINTS:
 DESCRIPTION:
-    ``CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS`` is defined if the
-    application has device drivers it needs to include in the Device Driver
-    Table.  This should be defined to the set of device driver entries that
-    will be placed in the table at the *FRONT* of the Device Driver Table and
-    initialized before any other drivers *EXCEPT* any BSP prerequisite drivers.
+    Driver Table.
 NOTES:
-    In some cases, it is used by System On Chip BSPs to support peripheral
-    buses beyond those normally found on the System On Chip. For example, this
-    is used by one RTEMS system which has implemented a SPARC/ERC32 based board
-    with VMEBus. The VMEBus Controller initialization is performed by a device
-    driver configured via this configuration parameter.
+    The value of this configuration option is placed after the entries defined by
+    :ref:`CONFIGURE_BSP_PREREQUISITE_DRIVERS` and before all other device driver
+    configuration options.
+    See :ref:`CONFIGURE_APPLICATION_EXTRA_DRIVERS` for an alternative placement
+    of application device driver initializers.
 .. index:: CONFIGURE_MAXIMUM_DRIVERS
diff --git a/c-user/config/general.rst b/c-user/config/general.rst
index 17ef1c8..b94bddf 100644
--- a/c-user/config/general.rst
+++ b/c-user/config/general.rst
@@ -83,22 +83,24 @@ CONFIGURE_INITIAL_EXTENSIONS
 CONSTANT:
     ``CONFIGURE_INITIAL_EXTENSIONS``
-DATA TYPE:
-RANGE:
-    Undefined or a list of one or more user extensions.
+OPTION TYPE:
 DEFAULT VALUE:
+VALUE CONSTRAINTS:
 DESCRIPTION:
-    If ``CONFIGURE_INITIAL_EXTENSIONS`` is defined by the application, then
-    this application specific set of initial extensions will be placed in the
-    initial extension table.
+    The value of this configuration option is used to initialize the table of
+    initial user extensions.
 NOTES:
-    None.
+    :ref:`BSP_INITIAL_EXTENSION` and after the entries of all other initial
+    user extensions.
 .. index:: CONFIGURE_INTERRUPT_STACK_SIZE
 .. index:: interrupt stack size
diff --git a/c-user/config/idle-task.rst b/c-user/config/idle-task.rst
index b2a8767..ff2168c 100644
--- a/c-user/config/idle-task.rst
+++ b/c-user/config/idle-task.rst
@@ -17,22 +17,27 @@ CONFIGURE_IDLE_TASK_BODY
 CONSTANT:
-DATA TYPE:
-    Function pointer.
-RANGE:
+OPTION TYPE:
 DEFAULT VALUE:
+    If :ref:`BSP_IDLE_TASK_BODY` is defined, then this will be the default value,
+    otherwise the default value is ``_CPU_Thread_Idle_body``.
+VALUE CONSTRAINTS:
 DESCRIPTION:
-    ``CONFIGURE_IDLE_TASK_BODY`` is set to the function name corresponding to
-    the application specific IDLE thread body.  If not specified, the BSP or
-    RTEMS default IDLE thread body will be used.
+    The value of this configuration option initializes the IDLE thread body.
 NOTES:
-    None.
+    IDLE threads must not block.  A blocking IDLE thread results in undefined
+    system behaviour because the scheduler assume that at least one ready thread
+    exists.
+    IDLE threads can be used to initialize the application, see configuration
+    option :ref:`CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION`.
 .. index:: CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
diff --git a/c-user/config/mpci.rst b/c-user/config/mpci.rst
index 7981fbc..ee0aff0 100644
--- a/c-user/config/mpci.rst
+++ b/c-user/config/mpci.rst
@@ -134,18 +134,19 @@ CONFIGURE_MP_MPCI_TABLE_POINTER
 CONSTANT:
     ``CONFIGURE_MP_MPCI_TABLE_POINTER``
-DATA TYPE:
-    pointer to ``rtems_mpci_table``
-RANGE:
-    undefined or valid pointer
+OPTION TYPE:
 DEFAULT VALUE:
+    The default value is ``&MPCI_table``.
+VALUE CONSTRAINTS:
+    The value of this configuration option must be a pointer to
+    :c:type:`rtems_mpci_table`.
 DESCRIPTION:
-    ``CONFIGURE_MP_MPCI_TABLE_POINTER`` is the pointer to the MPCI
-    Configuration Table.  The default value of this field is``&MPCI_table``.
+    The value of this configuration option initializes the MPCI Configuration
+    Table.
 NOTES:
     RTEMS provides a Shared Memory MPCI Device Driver which can be used on any
diff --git a/c-user/config/posix-init-thread.rst b/c-user/config/posix-init-thread.rst
index 6f47df4..5614342 100644
--- a/c-user/config/posix-init-thread.rst
+++ b/c-user/config/posix-init-thread.rst
@@ -18,23 +18,22 @@ CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
 CONSTANT:
     ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT``
-DATA TYPE:
-    POSIX thread function pointer (``void *(*entry_point)(void *)``).
-RANGE:
-    Undefined or a valid POSIX thread function pointer.
+OPTION TYPE:
 DEFAULT VALUE:
     The default value is ``POSIX_Init``.
+VALUE CONSTRAINTS:
+    pointer of the type ``void *( *entry_point )( void * )``.
 DESCRIPTION:
-    ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT`` is the entry point
-    (a.k.a. function name) of the single initialization thread defined by the
-    POSIX API Initialization Threads Table.
+    POSIX API initialization thread.
 NOTES:
-    The user must implement the function ``POSIX_Init`` or the function name
-    provided in this configuration parameter.
 .. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
@@ -64,7 +63,7 @@ VALUE CONSTRAINTS:
 DESCRIPTION:
     The value of this configuration option defines the thread stack size of the
-    POSIX API initialization threads.
 NOTES:
     None.
diff --git a/c-user/config/task-stack-alloc.rst b/c-user/config/task-stack-alloc.rst
index e031595..e1c48a5 100644
--- a/c-user/config/task-stack-alloc.rst
+++ b/c-user/config/task-stack-alloc.rst
@@ -22,28 +22,29 @@ CONFIGURE_TASK_STACK_ALLOCATOR
 CONSTANT:
     ``CONFIGURE_TASK_STACK_ALLOCATOR``
-DATA TYPE:
-    Function pointer.
-RANGE:
+OPTION TYPE:
 DEFAULT VALUE:
     The default value is ``_Workspace_Allocate``, which indicates that task
     stacks will be allocated from the RTEMS Workspace.
+VALUE CONSTRAINTS:
+    pointer of the type ``void *( *allocate )( size_t )``.
 DESCRIPTION:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR`` may point to a user provided routine to
-    allocate task stacks.
+    The value of this configuration option initializes the stack allocator
+    allocate handler.
 NOTES:
     A correctly configured system must configure the following to be consistent:
-    - ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT``
+    - :ref:`CONFIGURE_TASK_STACK_ALLOCATOR_INIT`
-    - ``CONFIGURE_TASK_STACK_ALLOCATOR``
+    - `CONFIGURE_TASK_STACK_ALLOCATOR`
-    - ``CONFIGURE_TASK_STACK_DEALLOCATOR``
+    - :ref:`CONFIGURE_TASK_STACK_DEALLOCATOR`
 .. index:: CONFIGURE_TASK_STACK_ALLOCATOR_INIT
@@ -55,29 +56,28 @@ CONFIGURE_TASK_STACK_ALLOCATOR_INIT
 CONSTANT:
-DATA TYPE:
-    Function pointer.
-RANGE:
-    Undefined, NULL or valid function pointer.
+OPTION TYPE:
 DEFAULT VALUE:
-    The default value is NULL, which indicates that task stacks will be
-    allocated from the RTEMS Workspace.
+    The default value is ``NULL``.
+VALUE CONSTRAINTS:
+    pointer of the type ``void ( *initialize )( size_t )`` or to ``NULL``.
 DESCRIPTION:
-    ``CONFIGURE_TASK_STACK_ALLOCATOR_INIT`` configures the initialization
-    method for an application or BSP specific task stack allocation
-    implementation.
+    initialization handler.
 NOTES:
+    - `CONFIGURE_TASK_STACK_ALLOCATOR_INIT`
+    - :ref:`CONFIGURE_TASK_STACK_ALLOCATOR`
 .. index:: CONFIGURE_TASK_STACK_DEALLOCATOR
 .. index:: task stack deallocator
@@ -90,25 +90,26 @@ CONFIGURE_TASK_STACK_DEALLOCATOR
 CONSTANT:
-DATA TYPE:
-    Function pointer.
-RANGE:
+OPTION TYPE:
 DEFAULT VALUE:
     The default value is ``_Workspace_Free``, which indicates that task stacks
+VALUE CONSTRAINTS:
+    pointer of the type ``void ( *deallocate )( void * )``.
 DESCRIPTION:
-    ``CONFIGURE_TASK_STACK_DEALLOCATOR`` may point to a user provided routine
-    to free task stacks.
+    deallocate handler.
 NOTES:
+    - `CONFIGURE_TASK_STACK_DEALLOCATOR`
2.16.4
