Undocumented configuration options
Sebastian Huber
Mon Mar 30 13:38:55 UTC 2020
On 30/03/2020 15:35, Joel Sherrill wrote:
> What about the
> CONFIGURE_FILESYSTEM_ENTRY_DEVFS
> CONFIGURE_FILESYSTEM_ENTRY_DOSFS
> CONFIGURE_FILESYSTEM_ENTRY_FTPFS
> CONFIGURE_FILESYSTEM_ENTRY_IMFS
> CONFIGURE_FILESYSTEM_ENTRY_JFFS2
> CONFIGURE_FILESYSTEM_ENTRY_NFS
> CONFIGURE_FILESYSTEM_ENTRY_RFS
> CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
> configuration options? Is this really something a user should be
> able to
> define?
> Chris will likely chime in later but I believe these are needed so that
> filesystem type is listed in the set of mountable filesystems. The mount
> command depends on those settings.
Yes, it depends on the settings, but the CONFIGURE_FILESYSTEM_ENTRY_*
options give you an extra level of control. For example, you can enable
the RFS with:
#define CONFIGURE_FILESYSTEM_ENTRY_RFS
Optionally, you can fine tune the entry:
#if defined(CONFIGURE_FILESYSTEM_RFS) \
&& !defined(CONFIGURE_FILESYSTEM_ENTRY_RFS)
#define CONFIGURE_FILESYSTEM_ENTRY_RFS \
{ RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise }
#endif
I am not sure if this fine tuning is really necessary.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/ba483d9c/attachment.html>
