[PATCH] user/gsoc: GSoC Getting Started Instructions
Niteesh G. S. niteesh.gs at gmail.com
Mon Mar 30 18:16:52 UTC 2020
Where should I put the additional instructions for creating and sending
patches?
I will try to send a patch most probably by tomorrow evening.
Meanwhile, can you have a look at the patch that I have sent?
https://lists.rtems.org/pipermail/devel/2020-March/058716.html
Thanks,
Niteesh
On Mon, Mar 30, 2020 at 9:40 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Mar 29, 2020 at 11:47 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 28/03/2020 19:47, Niteesh G. S. wrote:
> > We have an Installation chapter under the User manual
> https://docs.rtems.org/branches/master/user/installation/index.html
> > But it isn't detailed enough like the quick start guide. IMO it is the
> right place to add detailed instructions. It already has important
> > information for a good setup like sandboxing, differences between a
> release and dev. version, host toolchain setup and more.
> > Should we move all the details from quick-start chapter to the
> installation chapter and make the quick start guide simple enough for a
> > student to begin with.
> > We could add a subsection about GSoC under quick-start and ask the
> students to refer to the quick-start chapter.
> > We should really try to consolidate the documentation. Having mostly the
> same stuff in different places is a maintenance problem. The intention of
> the Quick Start chapter is to get started quickly step by step on a
> simulator platform which is able to run the RTEMS test suite properly. You
> should be able to use it as a template for your desired target system.
> Getting started on a simulator platform should be the right thing for a
> GSoC student?
> The concern is that the Quick Start includes a lot of extra material
> that makes it not so "Quick" to use. There are also many decisions
> that need to be made when following the quick start that makes it not
> exactly a linear set of directions.
> That said, I agree that consolidation is important. Niteesh, would you
> be willing to draft a subsection in the Quick Start (maybe near the
> beginning) that provides a set of instructions to walk-through the
> remainder of the quick start oriented toward GSoC students, pointing
> out the decision to make at each "decision point" -- such as, In
> Section 2.3 use the "Git" instructions; in Section 2.6 use the "Manual
> BSP Build", etc. These should be written as linked references to those
> sections/subsection names.
> Gedare
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200330/5df4436c/attachment.html>
