[PATCH 0/3] [5-freebsd-12] Using RTEMS tester to run testsuite
Moyano, Gabriel gabriel.moyano at dlr.de
Tue Mar 31 08:57:53 UTC 2020
Changes here follow the recomendation from:
https://www.mail-archive.com/devel@rtems.org/msg22029.html
Also testsuite/dhcpcd0x were automatized.
Moyano, Gabriel (3):
  testsuite: Using RTEMS tester functions at beginning and at the end of
    tests
  testsuite: User input define added
  testsuite/dhcpd0x: Tests automatized
 testsuite/arphole/test_main.c                      |  1 +
 testsuite/debugger01/test_main.c                   |  1 +
 testsuite/dhcpcd01/test_main.c                     | 24 +++++++++++++++++++---
 testsuite/dhcpcd02/test_main.c                     | 19 +++++++++++++++--
 testsuite/evdev01/init.c                           |  6 +++++-
 testsuite/foobarclient/test_main.c                 |  1 +
 testsuite/foobarserver/test_main.c                 |  1 +
 testsuite/ftpd01/test_main.c                       |  1 +
 testsuite/include/rtems/bsd/test/default-init.h    |  5 +++--
 .../include/rtems/bsd/test/default-network-init.h  |  5 +++--
 .../include/rtems/bsd/test/default-termios-init.h  |  5 +++--
 testsuite/ipsec01/test_main.c                      |  1 +
 testsuite/media01/test_main.c                      |  1 +
 testsuite/netshell01/test_main.c                   |  1 +
 testsuite/nfs01/test_main.c                        |  1 +
 testsuite/pf02/test_main.c                         |  1 +
 testsuite/ppp01/test_main.c                        |  1 +
 testsuite/swi01/init.c                             |  7 +++++--
 testsuite/telnetd01/test_main.c                    |  1 +
 testsuite/termios/test_main.c                      |  3 +--
 testsuite/timeout01/init.c                         |  7 +++++--
 testsuite/usb01/init.c                             |  6 +++++-
 testsuite/usbkbd01/init.c                          |  6 +++++-
 testsuite/usbmouse01/init.c                        |  6 +++++-
 testsuite/usbserial01/init.c                       |  6 +++++-
 testsuite/zerocopy01/test_main.c                   |  1 +
 waf_libbsd.py                                      |  2 +-
 27 files changed, 97 insertions(+), 23 deletions(-)
2.12.3
