[PATCH 3/3] testsuite/dhcpd0x: Tests automatized
Tue Mar 31 09:34:38 UTC 2020
On 31/03/2020 11:30, Gabriel.Moyano at dlr.de wrote:
> The short answer to your question (Do we see the environment in the test output after this change?) is no.  I understood that the idea of the test is to verify that the hook is called. If this is not correct, the change can be removed.
> Let me ask you if you consider useful the change in testsuite/dhcpcd02.
This test is only to see if the DHCP client works basically and what
information is provided by the server. I think this is more an
interactive test. You can also plug/unplug the cable and see what happens.
