Undocumented configuration options
Sebastian Huber
Tue Mar 31 10:50:56 UTC 2020
On 31/03/2020 10:14, Chris Johns wrote:
> On 2020-03-31 00:51, Joel Sherrill wrote:
>> On Mon, Mar 30, 2020 at 8:39 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> On 30/03/2020 15:35, Joel Sherrill wrote:
>>> What about the
>>> CONFIGURE_FILESYSTEM_ENTRY_DEVFS
>>> CONFIGURE_FILESYSTEM_ENTRY_DOSFS
>>> CONFIGURE_FILESYSTEM_ENTRY_FTPFS
>>> CONFIGURE_FILESYSTEM_ENTRY_IMFS
>>> CONFIGURE_FILESYSTEM_ENTRY_JFFS2
>>> CONFIGURE_FILESYSTEM_ENTRY_NFS
>>> CONFIGURE_FILESYSTEM_ENTRY_RFS
>>> CONFIGURE_FILESYSTEM_ENTRY_TFTPFS
>>> configuration options? Is this really something a user should
>>> be able to
>>> define?
>>> Chris will likely chime in later but I believe these are needed so
>>> that
>>> filesystem type is listed in the set of mountable filesystems.
>>> The mount
>>> command depends on those settings.
>> Yes, it depends on the settings, but the
>> CONFIGURE_FILESYSTEM_ENTRY_* options give you an extra level of
>> control. For example, you can enable the RFS with:
>> #define CONFIGURE_FILESYSTEM_ENTRY_RFS
>> Optionally, you can fine tune the entry:
>> #if defined(CONFIGURE_FILESYSTEM_RFS) \
>> && !defined(CONFIGURE_FILESYSTEM_ENTRY_RFS)
>> #define CONFIGURE_FILESYSTEM_ENTRY_RFS \
>> { RTEMS_FILESYSTEM_TYPE_RFS, rtems_rfs_rtems_initialise }
>> #endif
>> I am not sure if this fine tuning is really necessary.
>> Me either. Looks like a way for someone to provide their own
>> version of the definition which seems in the class of defining your
>> own Configuration Table structures. And we removed those.
>> Let's wait for Chris. :)
> This dates back to 2010 [1] and I suspect I was attempting to follow
> the way confdefs tables were defined then. Anything that makes things
> simpler is good.
Ok, good. Here is a patch which removes these configuration options:
https://lists.rtems.org/pipermail/devel/2020-March/058782.html
I will now start to document the following options:
CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
CONFIGURE_ATA_DRIVER_TASK_PRIORITY
CONFIGURE_CBS_MAXIMUM_SERVERS
CONFIGURE_DISABLE_NEWLIB_REENTRANCY
CONFIGURE_EXECUTIVE_RAM_SIZE
CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
CONFIGURE_FILESYSTEM_ALL
CONFIGURE_FILESYSTEM_DEVFS
CONFIGURE_FILESYSTEM_DOSFS
CONFIGURE_FILESYSTEM_FTPFS
CONFIGURE_FILESYSTEM_IMFS
CONFIGURE_FILESYSTEM_JFFS2
CONFIGURE_FILESYSTEM_NFS
CONFIGURE_FILESYSTEM_TFTPFS
CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
CONFIGURE_MALLOC_DIRTY
CONFIGURE_MAXIMUM_POSIX_SHMS
CONFIGURE_SCHEDULER_ASSIGNMENTS
CONFIGURE_SCHEDULER_STRONG_APA
CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
CONFIGURE_TASK_STACK_FROM_ALLOCATOR
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200331/8b218b79/attachment-0001.html>
