[PATCH] doc: Moving BSP Content to User Manual (#3905)
Chris Johns
chrisj at rtems.org
Tue Mar 31 22:15:03 UTC 2020
On 2020-04-01 04:43, mritunjaysharma394 at gmail.com wrote:
> From: Mritunjay <mritunjaysharma394 at gmail.com>
> user/bsps/bsps-m68k.rst | 174 +++++++++++++++++++++++++++++++++++++++-
> 1 file changed, 172 insertions(+), 2 deletions(-)
> diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> index 60882fb..0f60d8b 100644
> --- a/user/bsps/bsps-m68k.rst
> +++ b/user/bsps/bsps-m68k.rst
> @@ -1,6 +1,7 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> .. Copyright (C) 2018 embedded brains GmbH
> +.. Copyright (C) 2020 Mritunjay Sharma
Did you write this documentation? I suggest you look at the history in
trac to see if you can find the wiki's author.
> m68k (Motorola 68000 / ColdFire)
> @@ -53,7 +54,16 @@ TODO.
> mcf5329
> -TODO.
> +Overview
> +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a Motorola evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The development kit features the MCF5329 based Fire Engine, as well as a plug-in system-on-module containing 32 MB of DDR-SDRAM. The board also includes 2 MB of boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard 800x600 LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100 Ethernet.
This line is too long. Please have a look at ...
https://git.rtems.org/rtems-docs/tree/README.txt#n415
It should help guide the formatting we require.
> +This BSP exists in 4.9 and later.
> +You can find the link to MCF5329 Reference Manual below:
> +* `MCF5329 Reference Manual <https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
> mrm332
> @@ -73,7 +83,167 @@ TODO.
> mvme162
> -TODO.
> +Overview
> +The MVME162 family provides OEMs and solution developers an ideal platform for embedded monitoring and control apllications it allows an OEM to minimize engineering expenses while integrating value-added hardware and software applications onto an off-the-shelf product. In order to provide the wide range of solutions, the MVME162 allows a variety of MPU, memory, and interface options such as floating-point, Ethernet, SCSI, and VME. The result is a variation of the MVME162 which most closely fits the application requirement.
> +There are a large number of model variations on this board. This was the first user submitted BSP and continues to be a fairly popular simply because at one point it was the highest selling VMEBus board of all time.
> +Board Setup
> +RTEMS Lab Board
What is this?
> +The env settings:
> +.. code-block:: none
> + MPU Clock Speed =25Mhz
> + 162-Bug>env
> + Bug or System environment [B/S] = B?
> + Field Service Menu Enable [Y/N] = N?
> + Remote Start Method Switch [G/M/B/N] = B?
> + Probe System for Supported I/O Controllers [Y/N] = Y?
> + Negate VMEbus SYSFAIL* Always [Y/N] = N?
> + Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> + Local SCSI Bus Negotiations Type [A/S/N] = A?
> + Industry Pack Reset on Debugger Startup [Y/N] = Y?
> + Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y?
> + Auto Boot Enable [Y/N] = N?
> + Auto Boot at power-up only [Y/N] = Y?
> + Auto Boot Controller LUN = 00?
> + Auto Boot Device LUN = 00?
> + Auto Boot Abort Delay = 15?
> + Auto Boot Default String [NULL for a empty string] = ?
> + ROM Boot Enable [Y/N] = N?
> + ROM Boot at power-up only [Y/N] = Y?
> + ROM Boot Enable search of VMEbus [Y/N] = N?
> + ROM Boot Abort Delay = 0?
> + ROM Boot Direct Starting Address = FF800000?
> + ROM Boot Direct Ending Address = FFDFFFFC?
> + Network Auto Boot Enable [Y/N] = N?
> + Network Auto Boot at power-up only [Y/N] = Y?
> + Network Auto Boot Controller LUN = 00?
> + Network Auto Boot Device LUN = 00?
> + Network Auto Boot Abort Delay = 5?
> + Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
> + Memory Search Starting Address = 00000000?
> + Memory Search Ending Address = 01000000?
> + Memory Search Increment Size = 00010000?
> + Memory Search Delay Enable [Y/N] = N?
> + Memory Search Delay Address = FFFFD20F?
> + Memory Size Enable [Y/N] = Y?
> + Memory Size Starting Address = 00000000?
> + Memory Size Ending Address = 01000000?
> + Base Address of Dynamic Memory = 00000000?
> + Size of Parity Memory = 00000000?
> + Size of ECC Memory Board #0 = 01000000?
> + Size of ECC Memory Board #1 = 00000000?
> + Base Address of Static Memory = FFE00000?
> + Size of Static Memory = 00020000?
> + Slave Enable #1 [Y/N] = Y?
> + Slave Starting Address #1 = 00000000?
> + Slave Ending Address #1 = 00FFFFFF?
> + Slave Address Translation Address #1 = 00000000?
> + Slave Address Translation Select #1 = 00000000?
> + Slave Control #1 = 03FF?
> + Slave Enable #2 [Y/N] = N?
> + Slave Starting Address #2 = 00000000?
> + Slave Ending Address #2 = 00000000?
> + Slave Address Translation Address #2 = 00000000?
> + Slave Address Translation Select #2 = 00000000?
> + Slave Control #2 = 0000?
> + Master Enable #1 [Y/N] = Y?
> + Master Starting Address #1 = 01000000?
> + Master Ending Address #1 = EFFFFFFF?
> + Master Control #1 = 0D?
> + Master Enable #2 [Y/N] = N?
> + Master Starting Address #2 = 00000000?
> + Master Ending Address #2 = 00000000?
> + Master Control #2 = 00?
> + Master Enable #3 [Y/N] = N?
> + Master Starting Address #3 = 00000000?
> + Master Ending Address #3 = 00000000?
> + Master Control #3 = 00?
> + Master Enable #4 [Y/N] = N?
> + Master Starting Address #4 = 00000000?
> + Master Ending Address #4 = 00000000?
> + Master Address Translation Address #4 = 00000000?
> + Master Address Translation Select #4 = 00000000?
> + Master Control #4 = 00?
> + Short I/O (VMEbus A16) Enable [Y/N] = Y?
> + Short I/O (VMEbus A16) Control = 01?
> + F-Page (VMEbus A24) Enable [Y/N] = Y?
> + F-Page (VMEbus A24) Control = 02?
> + ROM Access Time Code = 03?
> + FLASH Access Time Code = 02?
> + MCC Vector Base = 05?
> + VMEC2 Vector Base #1 = 06?
> + VMEC2 Vector Base #2 = 07?
> + VMEC2 GCSR Group Base Address = D2?
> + VMEC2 GCSR Board Base Address = 00?
> + VMEbus Global Time Out Code = 01?
> + Local Bus Time Out Code = 02?
> + VMEbus Access Time Out Code = 02?
> + IP A Base Address = 00000000?
> + IP B Base Address = 00000000?
> + IP C Base Address = 00000000?
> + IP D Base Address = 00000000?
> + IP D/C/B/A Memory Size = 00000000?
> + IP D/C/B/A General Control = 00000000?
> + IP D/C/B/A Interrupt 0 Control = 00000000?
> + IP D/C/B/A Interrupt 1 Control = 00000000?
> +The niot settings:
`niot` means what?
> + 162-Bug>niot
> + Controller LUN =00?
> + Device LUN =00?
> + Node Control Memory Address =FFE10000?
> + Client IP Address =192.168.1.245?
> + Server IP Address =192.168.1.92?
> + Subnet IP Address Mask =255.255.255.0?
> + Broadcast IP Address =192.168.1.255?
> + Gateway IP Address =0.0.0.0?
> + Boot File Name ("NULL" for None) =/mvme162.img?
> + Argument File Name ("NULL" for None) =?
> + Boot File Load Address =00020000?
> + Boot File Execution Address =00020000?
> + Boot File Execution Delay =00000000?
> + Boot File Length =00000000?
> + Boot File Byte Offset =00000000?
> + BOOTP/RARP Request Retry =00?
> + TFTP/ARP Request Retry =00?
> + Trace Character Buffer Address =00000000?
> + BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> + BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
> +Downloading and Executing
> +Download from the tftp server using the 162-Bug's "nbo" command:
tftp -> TFTP
> + 162-Bug>nbo
> + Network Booting from: VME162, Controller 0, Device 0
> + Loading: /mvme162.img
> + Client IP Address = 192.168.1.245
> + Server IP Address = 192.168.1.92
> + Gateway IP Address = 0.0.0.0
> + Subnet IP Address Mask = 255.255.255.0
> + Boot File Name = /mvme162.img
> + Argument File Name =
> + Network Boot File load in progress... To abort hit <BREAK>
> + Bytes Received =&356528, Bytes Loaded =&356528
> + Bytes/Second =&89132, Elapsed Time =4 Second(s)
> +The program will automatically run when download is complete.
> mvme167
