[PATCH 2/2] rtems-release-branch: Added a script file to branch repositories.
G S Niteesh Babu
niteesh.gs at gmail.com
Sat May 2 03:52:12 UTC 2020
rtems-release-branch | 146 +++++++++++++++++++++++++++++++++++++++++++
1 file changed, 146 insertions(+)
create mode 100755 rtems-release-branch
diff --git a/rtems-release-branch b/rtems-release-branch
new file mode 100755
index 0000000..ae8e06c
--- /dev/null
+++ b/rtems-release-branch
@@ -0,0 +1,146 @@
+#! /bin/sh
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2020 Niteesh Babu <niteesh.gs at gmail.com>
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+set -e
+# This is the top level RTEMS release script. Supply the version and and the
+# release.
+. ./rtems-release-version
+echo "RTEMS Release, v${rtems_release_version}"
+# Global release top path.
+export release_top=${PWD}
+# Usage for this tool.
+usage() {
+ echo "Usage: $0 [-t] [-p] user version" 1>&2
+ echo " where:" 1>&2
+ echo " user : Your git user name" 1>&2
+ echo " version : The version of RTEMS, eg 5" 1>&2
+ echo " -t : Git protocol will be used for cloning (for testing)." 1>&2
+ echo " -p : Push the changes." 1>&2
+ exit 1
+# Defaults.
+. ${release_top}/rtems-release-defaults
+# Option defaults
+clone_url=
+push=no
+# Manage the command line.
+while getopts "tp" opt; do
+ case "${opt}" in
+ t)
+ clone_url=git://git.rtems.org
+ p)
+ push=yes
+ usage
+ esac
+done
+shift $((OPTIND-1))
+if [ $# -ne 2 ]; then
+ echo "error: 2 arguments must be supplied, your git user name, version. See -h for help"
+ exit 1
+fi
+user=$1
+version=$2
+# Check if clone_url is empty.
+if [ -z "${clone_url}" ]; then
+ clone_url=ssh://${user}@dispatch.rtems.org/data/git
+fi
+# The branching workspace.
+ws_branch=${version}-branched
+# Version configuration. Overrides defaults.
+if [ -f rtems-release-${version}-conf ]; then
+ rtems_release_conf=rtems-release-${version}-conf
+ . rtems-release-${version}-conf
+fi
+# Clean the branched directory away.
+rm -rf ${ws_branch}
+mkdir ${ws_branch}
+# Clone and branch the repositories.
+cd ${ws_branch}
+ for r in ${rtems_repos}
+ do
+ echo "git clone ${clone_url}/${r} ${r}"
+ git clone ${clone_url}/${r} ${r}
+ cd ${r}
+ echo "git checkout -b ${version} origin/master"
+ git checkout -b ${version} origin/master
+ cd ..
+ done
+ if [ ${push} = yes ]; then
+ do
+ cd ${r}
+ echo "git push origin ${version}"
+ git push origin ${version}
+ cd ..
+ done
+ fi
+ cd ..
+exit 0
2.17.1
