RSB fails to build qemu.bset
Cláudio Maia
clrrm at isep.ipp.pt
Sun May 3 12:11:34 UTC 2020
On 02/05/20 19:33, Joel Sherrill wrote:
> On Sat, May 2, 2020, 12:42 PM Cláudio Maia <clrrm at isep.ipp.pt <mailto:clrrm at isep.ipp.pt>> wrote:
> Hello everyone,
> I'm trying to build the toolchain for the build set devel/qemu.bset with the goal of executing RTEMS applications on top of LEON3 bsp on QEMU.
> Unfortunately, when I build the toolchain using:
> $ ../source-builder/sb-set-builder --prefix=$RTEMS/5 devel/qemu.bset
> the following error occurs, for which I don't have a clue on how to fix:
<snip>
> Unescaped left brace in regex is illegal here in regex; marked by <-- HERE in m/^\@strong{ <-- HERE (.*)}$/ at /home/crrm/Documents/projects/rtems/rsb/rtems/build/qemu-42d58e7c6760cb9c55627c28ae538e27dcf2f144-x86_64-linux-gnu-1/qemu-42d58e7c6760cb9c55627c28ae538e27dcf2f144/scripts/texi2pod.pl <http://texi2pod.pl> line 320.
> Makefile:515: recipe for target 'kvm_stat.1' failed
> make: *** [kvm_stat.1] Error 255
> shell cmd failed: /bin/sh -ex /home/crrm/Documents/projects/rtems/rsb/rtems/build/qemu-42d58e7c6760cb9c55627c28ae538e27dcf2f144-x86_64-linux-gnu-1/do-build
> Can someone help me fixing this?
> As a side note, I was looking for information on RTEMS documentation about how to run RTEMS applications on LEON3 under QEMU, and I could not find any.
> Do you know if such information exists?
> If this is a recent Linux distribution, try the qemu4 bset.
This is the case. Building from scratch with devel/qemu4.bset works as expected.
> The qemu.bset is for an older version of qemu which seems to have build issues on newer hosts.
> Qemu5 was also recently released.
> I suspect we need to renamed this to have a major number on the end. That might encourage picking a newer release.
> FWIW qemu4 builds on Centos 7 which means newer qemu on older Linux works where older qemu on newer Linux doesn't.
> --joel
Thank you.
Regards,
Cláudio
