Fwd: Build FreeBSD: FAILED 5/bsps/erc32 on x86_64-freebsd12.1 (rtems-tools-5.0.0-m2005-1-1)
Joel Sherrill
joel at rtems.org
Sun May 3 18:33:33 UTC 2020
All the m2005 SPARC bsp bsets appear to be failing on FreeBSD 12.1.
Anyone spot anything in this report?
---------- Forwarded message ---------
Date: Sun, May 3, 2020, 11:57 AM
Subject: Build FreeBSD: FAILED 5/bsps/erc32 on x86_64-freebsd12.1
To: <build at rtems.org>
RTEMS Source Builder - Set Builder, 5.0.0-m2005-1
Host: FreeBSD-12.1-RELEASE-p3-amd64-64bit-ELF
FreeBSD rtbf64b 12.1-RELEASE-p3 FreeBSD 12.1-RELEASE-p3 GENERIC amd64
amd64
Build Time: 0:53:15.406600
Output
Build Set: 5/bsps/erc32
Build Set: 5/rtems-sparc.bset
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-freebsd12.1-1
building: autoconf-2.69-x86_64-freebsd12.1-1
sizes: autoconf-2.69-x86_64-freebsd12.1-1: 7.509MB (installed: 0.000B)
cleaning: autoconf-2.69-x86_64-freebsd12.1-1
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-freebsd12.1-1
building: automake-1.12.6-x86_64-freebsd12.1-1
sizes: automake-1.12.6-x86_64-freebsd12.1-1: 8.330MB (installed: 0.000B)
cleaning: automake-1.12.6-x86_64-freebsd12.1-1
Build Sizes: usage: 8.330MB total: 328.421MB (sources: 328.070MB, patches:
359.714KB, installed 0.000B)
Build Set: Time 0:00:10.609918
Build Set: 5/rtems-autotools-base.bset
sizes: autoconf-2.69-x86_64-freebsd12.1-1: 10.526MB (installed: 3.021MB)
reporting: tools/rtems-autoconf-2.69-1.cfg ->
autoconf-2.69-x86_64-freebsd12.1-1.txt
autoconf-2.69-x86_64-freebsd12.1-1.xml
sizes: automake-1.12.6-x86_64-freebsd12.1-1: 10.593MB (installed: 2.265MB)
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-freebsd12.1-1.txt
automake-1.12.6-x86_64-freebsd12.1-1.xml
staging: autoconf-2.69-x86_64-freebsd12.1-1 ->
/usr/home/joel/rtems-cron-5.0.0-m2005-1/rtems-source-builder-5.0.0-m2005-1/rtems/build/tmp/sb-1002-staging
staging: automake-1.12.6-x86_64-freebsd12.1-1 ->
Build Sizes: usage: 15.879MB total: 333.707MB (sources: 328.070MB, patches:
359.714KB, installed 5.286MB)
Build Set: Time 0:00:21.116572
Build Set: Time 0:00:31.735881
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-freebsd12.1-1
building: expat-2.1.0-x86_64-freebsd12.1-1
sizes: expat-2.1.0-x86_64-freebsd12.1-1: 4.788MB (installed: 620.240KB)
cleaning: expat-2.1.0-x86_64-freebsd12.1-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-freebsd12.1-1.txt
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-freebsd12.1-1.xml
config: tools/rtems-gdb-9.1-1.cfg
package: sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1
building: sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1
sizes: sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1: 249.289MB (installed:
11.915MB)
cleaning: sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1
reporting: tools/rtems-gdb-9.1-1.cfg ->
sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1.txt
sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1.xml
config: tools/rtems-binutils-2.34.cfg
package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
building: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
sizes: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1: 305.902MB
(installed: 29.966MB)
cleaning: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
reporting: tools/rtems-binutils-2.34.cfg ->
sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.txt
sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1.xml
config: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
package: sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1
building: sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1
sizes: sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1: 4.717GB
(installed: 889.686MB)
cleaning: sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1
reporting: tools/rtems-gcc-7.5.0-newlib-7947581.cfg ->
sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1.txt
sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1.xml
config: tools/rtems-tools-5-1.cfg
package: rtems-tools-5.0.0-m2005-1-1
building: rtems-tools-5.0.0-m2005-1-1
error: building rtems-tools-5.0.0-m2005-1-1
Build FAILED
See error report: rsb-report-rtems-tools-5.0.0-m2005-1-1.txt
Build Set: Time 0:53:15.401143
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Sun May 3 08:15:50 2020
Report: devel/expat-2.1.0-1.cfg
RTEMS Source Builder Release
Version: 5.0.0-m2005-1
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-freebsd12.1-1
Config: devel/expat-2.1.0-1.cfg
Summary:
Expat XML Parser v2.1.0 for target sparc-rtems5 on host x86_64-freebsd12.1
URL:
http://expat.sourceforge.net/
Version:
2.1.0
Release:
1
Sources: 1
1:
https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz
sha256:
823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7eb86
Patches: 0
Preparation:
build_top=$(pwd)
%setup source expat -q -n expat-2.1.0
%setup patch expat -p1
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
# Host and build flags, Cross build if host and build are different and
# Cxc build if target is deifned and also different.
# Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
if test "x86_64-freebsd12.1" != "x86_64-freebsd12.1" ; then
# Cross build
CC=$(echo "x86_64-freebsd12.1-gcc" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "x86_64-freebsd12.1-g++" | sed -e 's,-std=gnu99 ,,')
CPPFLAGS="${SB_HOST_CPPFLAGS}"
CFLAGS="${SB_HOST_CFLAGS}"
CXXFLAGS="${SB_HOST_CXXFLAGS}"
LDFLAGS="${SB_HOST_LDFLAGS}"
LDLIBS="${SB_HOST_LIBS}"
# Host
CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
LDLIBS_FOR_HOST="${SB_HOST_LIBS}"
CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
# Build
CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
LDLIBS_FOR_BUILD="${SB_BUILD_LIBS}"
CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
CC_FOR_BUILD=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e
's,-std=gnu99 ,,')
CXX_FOR_BUILD=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e
's,-std=gnu99 ,,')
else
LDFLAGS="${SB_BUILD_LDFLAGS}"
LDLIBS="${SB_BUILD_LIBS}"
CC=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
CXX=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
CC_FOR_BUILD=${CC}
CXX_FOR_BUILD=${CXX}
fi
export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
./configure --build=x86_64-freebsd12.1 --host=x86_64-freebsd12.1
--verbose --prefix=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
--bindir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin
--exec-prefix=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
--includedir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/include
--libdir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/lib
--mandir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man
--infodir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/info
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
rm -rf $SB_BUILD_ROOT
cd expat-2.1.0
gmake DESTDIR=$SB_BUILD_ROOT install
cd ${build_top}
Summary:
URL:
Version:
2.1.0
Release:
1
Sources: 1
1:
sha256:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
cd expat-2.1.0
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
cd expat-2.1.0
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun May 3 08:20:37 2020
Report: tools/rtems-gdb-9.1-1.cfg
Build Set: (1) tools/rtems-gdb-9.1-1.cfg
Build Set: (2) tools/rtems-gdb-9.1-1.cfg
Package: sparc-rtems5-gdb-9.1-x86_64-freebsd12.1-1
Config: tools/rtems-gdb-9.1-1.cfg
Summary:
GDB v9.1 for target sparc-rtems5 on host x86_64-freebsd12.1
URL:
http://www.gnu.org/software/gdb/
Version:
9.1
Release:
1
Sources: 1
1: http://ftp.gnu.org/gnu/gdb/gdb-9.1.tar.xz
sha512:
hM3UCNgKP8V3neRZxbJhVNMbMp695+OqeHmfseskXYtkuMjuckI4Kh29lbTm+dhP70HRKgZGqnXT3uRwnqH25w==
Patches: 0
Preparation:
build_top=$(pwd)
gdb_source="gdb-9.1"
source_dir_gdb=${gdb_source}
%setup source gdb -q -n ${gdb_source}
%setup patch gdb -p1
cd ${build_top}
Build:
build_top=$(pwd)
# Cross-build (Xc) if no target or the host and target match.
# Canadian-cross (Cxc) if build, host and target are all different.
if test -z "sparc-rtems5" -o "x86_64-freebsd12.1" == "sparc-rtems5" ;
then
build_dir="build-xc"
else
build_dir="build-cxc"
fi
else
build_dir="build"
fi
mkdir -p ${build_dir}
cd ${build_dir}
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
GDB_LIBS_STATIC="-lexpat"
else
GDB_LIBS="-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic"
fi
LIBS_STATIC=${GDB_LIBS_STATIC} LIBS=${GDB_LIBS}
../${source_dir_gdb}/configure --build=x86_64-freebsd12.1
--host=x86_64-freebsd12.1 --target=sparc-rtems5 --verbose --disable-nls
--disable-gas --disable-binutils --disable-ld --disable-gold
--disable-gprof --without-included-gettext --disable-win32-registry
--disable-werror --disable-sim --without-zlib --with-expat
--with-guile=no --with-libiconv-prefix=/usr/local
--with-python=/usr/local/bin/python3
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
/bin/rm -rf $SB_BUILD_ROOT
cd ${build_dir}
/bin/rm -rf
$SB_BUILD_ROOT/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/info/
configure.info*
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/info/dir
touch
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun May 3 08:20:38 2020
Summary:
URL:
Version:
9.1
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
else
fi
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
/bin/rm -rf
configure.info*
/bin/rm -f
touch
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun May 3 08:21:55 2020
Report: tools/rtems-binutils-2.34.cfg
Build Set: (1) tools/rtems-binutils-2.34.cfg
Build Set: (2) tools/rtems-binutils-2.34.cfg
Package: sparc-rtems5-binutils-2.34-x86_64-freebsd12.1-1
Config: tools/rtems-binutils-2.34.cfg
Summary:
Binutils v2.34 for target sparc-rtems5 on host x86_64-freebsd12.1
URL:
http://sources.redhat.com/binutils
Version:
2.34
Release:
1
Sources: 1
1: https://ftp.gnu.org/gnu/binutils/binutils-2.34.tar.bz2
sha512:
f47e7304e102c7bbc97958a08093e27796b9051d1567ce4fbb723d39ef3e29efa325ee14a1bdcc462a925a7f9bbbc9aee28294c6dc23850f371030f3835a8067
Patches: 0
Preparation:
build_top=$(pwd)
binutils_source="binutils-2.34"
source_dir_binutils=${binutils_source}
%setup source binutils -q -n ${binutils_source}
%setup patch binutils -p1
cd ${build_top}
Build:
build_top=$(pwd)
then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_binutils}/configure --build=x86_64-freebsd12.1
--disable-gdb --disable-libdecnumber --disable-readline --disable-sim
--enable-deterministic-archives --enable-64-bit-bfd --disable-lto
--without-included-gettext --disable-win32-registry --disable-werror
gmake -j 4 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
/bin/rm -rf
configure.info*
/bin/rm -f
touch
mkdir -p
$SB_BUILD_ROOT/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/locale
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/lib/libiberty*
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin/sparc-rtems5-dlltool;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man/man1/sparc-rtems5-dlltool*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin/sparc-rtems5-nlmconv;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man/man1/sparc-rtems5-nlmconv*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin/sparc-rtems5-windres;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man/man1/sparc-rtems5-windres*
fi
if test ! -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin/sparc-rtems5-windmc;
then
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man/man1/sparc-rtems5-windmc*
fi
cd ${build_top}
Summary:
URL:
Version:
2.34
Release:
1
Sources: 1
sha512:
Patches: 0
Preparation:
build_top=$(pwd)
cd ${build_top}
Build:
build_top=$(pwd)
then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
gmake -j 4 all
cd ${build_top}
Install:
cd ${build_top}
cd ${build_dir}
/bin/rm -rf
configure.info*
/bin/rm -f
touch
mkdir -p
/bin/rm -f
if test ! -f
then
/bin/rm -f
fi
if test ! -f
then
/bin/rm -f
fi
if test ! -f
then
/bin/rm -f
fi
if test ! -f
then
/bin/rm -f
fi
cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sun May 3 09:08:25 2020
Report: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Build Set: (1) tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Build Set: (2) tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Package: sparc-rtems5-gcc-7.5.0-newlib-7947581-x86_64-freebsd12.1-1
Config: tools/rtems-gcc-7.5.0-newlib-7947581.cfg
Summary:
GCC v7.5.0 and Newlib v7947581 for target sparc-rtems5 on host
x86_64-freebsd12.1
URL:
http://gcc.gnu.org/
Version:
7.5.0
Release:
1
Sources: 6
1: https://ftp.gnu.org/gnu/gcc/gcc-7.5.0/gcc-7.5.0.tar.xz
sha512:
fe716cc19f2e3255d3a8b1b8290777bf769c6d98e6e0b07b81a3d6ad43f8af74cb170dfa18b1555dbfcd3f55ae582b91a286ccef496b9b65c1579902f96a1f60
2: https://ftp.gnu.org/gnu/mpc/mpc-1.0.3.tar.gz
sha512:
0028b76df130720c1fad7de937a0d041224806ce5ef76589f19c7b49d956071a683e2f20d154c192a231e69756b19e48208f2889b0c13950ceb7b3cfaf059a43
3: --rsb-file=newlib-7947581.tar.gz
https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/7947581
No checksum
4: https://gcc.gnu.org/pub/gcc/infrastructure/isl-0.16.1.tar.bz2
sha512:
c188667a84dc5bdddb4ab7c35f89c91bf15a8171f4fcaf41301cf285fb7328846d9a367c096012fec4cc69d244f0bc9e95d84c09ec097394cd4093076f2a041b
5: https://ftp.gnu.org/gnu/gmp/gmp-6.1.0.tar.bz2
sha512:
3c82aeab9c1596d4da8afac2eec38e429e84f3211e1a572cf8fd2b546493c44c039b922a1133eaaa48bd7f3e11dbe795a384e21ed95cbe3ecc58d7ac02246117
6: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2
sha512:
51066066ff2c12ed2198605ecf68846b0c96b548adafa5b80e0c786d0df488411a5e8973358fce7192dc977ad4e68414cf14500e3c39746de62465eb145bb819
Patches: 1
1: https://gcc.gnu.org/bugzilla/attachment.cgi?id=41380
No checksum
Preparation:
build_top=$(pwd)
gcc_source="gcc-7.5.0"
source_dir_gcc=${gcc_source}
%setup source gcc -q -n ${gcc_source}
%setup patch gcc -p1
cd ${build_top}
source_dir_newlib=sourceware-mirror-newlib-cygwin-7947581
%setup source newlib -q -D -n ${source_dir_newlib}
%setup patch newlib -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/newlib
ln -s $PWD/${source_dir_newlib}/newlib ${source_dir_gcc}/newlib
source_dir_isl="isl-0.16.1"
%setup source isl -q -D -n isl-0.16.1
%setup patch isl -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/isl
ln -s $PWD/${source_dir_isl} ${source_dir_gcc}/isl
source_dir_mpfr="mpfr-3.1.4"
%setup source mpfr -q -D -n mpfr-3.1.4
%setup patch mpfr -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpfr
ln -s $PWD/${source_dir_mpfr} ${source_dir_gcc}/mpfr
source_dir_mpc="mpc-1.0.3"
%setup source mpc -q -D -n mpc-1.0.3
%setup patch mpc -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/mpc
ln -s $PWD/${source_dir_mpc} ${source_dir_gcc}/mpc
source_dir_gmp="gmp-6.1.0"
%setup source gmp -q -D -n gmp-6.1.0
%setup patch gmp -p1
cd ${build_top}
/bin/rm -f ${source_dir_gcc}/gmp
ln -s $PWD/${source_dir_gmp} ${source_dir_gcc}/gmp
echo "RTEMS 5, RSB 5.0.0-m2005-1, Newlib 7947581" >
${source_dir_gcc}/gcc/DEV-PHASE
cd ${source_dir_gcc}
contrib/gcc_update --touch
cd ${build_top}
Build:
build_top=$(pwd)
then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
languages="$languages,c++"
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
../${source_dir_gcc}/configure
--exec_prefix=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5
--libexecdir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/libexec
--datadir=/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share
--target=sparc-rtems5 --disable-libstdcxx-pch --with-gnu-as --with-gnu-ld
--verbose --with-newlib --disable-nls --without-included-gettext
--disable-win32-registry --enable-version-specific-runtime-libs
--disable-lto --enable-newlib-io-c99-formats --enable-newlib-iconv
--enable-newlib-iconv-encodings=big5,cp775,cp850,cp852,cp855,\
cp866,euc_jp,euc_kr,euc_tw,iso_8859_1,iso_8859_10,iso_8859_11,\
iso_8859_13,iso_8859_14,iso_8859_15,iso_8859_2,iso_8859_3,\
iso_8859_4,iso_8859_5,iso_8859_6,iso_8859_7,iso_8859_8,iso_8859_9,\
iso_ir_111,koi8_r,koi8_ru,koi8_u,koi8_uni,ucs_2,ucs_2_internal,\
ucs_2be,ucs_2le,ucs_4,ucs_4_internal,ucs_4be,ucs_4le,us_ascii,\
utf_16,utf_16be,utf_16le,utf_8,win_1250,win_1251,win_1252,\
win_1253,win_1254,win_1255,win_1256,win_1257,win_1258 --enable-threads
--disable-plugin --enable-libgomp --enable-languages="$languages"
if test "%_host" != "%_build" ; then
mkdir -p gcc/include
cp ../${source_dir_gcc}/gcc/gsyslimits.h gcc/include/syslimits.h
fi
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f
${SB_BUILD_ROOT}/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/lib/libiberty.a
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/bin/sparc-rtems5-c++filt
/bin/rm -f
/bin/rm -f
$SB_BUILD_ROOT/home/joel/rtems-cron-5.0.0-m2005-1/tools/5/share/man/man3/*ffi*
/bin/rm -rf ${source_dir_gcc}/newlib
/bin/rm -rf ${source_dir_gcc}/mpfr
/bin/rm -rf ${source_dir_gcc}/mpc
/bin/rm -rf ${source_dir_gcc}/gmp
Summary:
x86_64-freebsd12.1
URL:
http://gcc.gnu.org/
Version:
7.5.0
Release:
1
Sources: 6
sha512:
sha512:
No checksum
sha512:
sha512:
sha512:
Patches: 1
No checksum
Preparation:
build_top=$(pwd)
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
cd ${build_top}
Build:
build_top=$(pwd)
then
else
fi
else
build_dir="build"
fi
cd ${build_dir}
languages="c"
checked).
# Cross build
# Host
# Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
else
CC_FOR_BUILD=${CC}
fi
fi
gmake -j 4 all
cd ${build_top}
Install:
build_top=$(pwd)
cd ${build_dir}
cd ${build_top}
/bin/rm -f
/bin/rm -f
/bin/rm -f
/bin/rm -f
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200503/178d5008/attachment-0001.html>
