[PATCH rtems_waf] rtems: Add uninstall option to the list of commands
Chris Johns
chrisj at rtems.org
Sun May 3 23:09:38 UTC 2020
Hi
Are uninstall command useful with RTEMS? A use case that shows how it
would be used may help.
I use separate prefixes to manage this. We do not track common files
when installing to a common prefix so building ARM and then PowerPC to
the same prefix then uninstalling only the PowerPC build would remove
files needed by ARM.
On 4/5/20 5:04 am, Vijay Kumar Banerjee wrote:
> rtems.py | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/rtems.py b/rtems.py
> index ceabcd9..067a213 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -131,7 +131,7 @@ def init(ctx, filters = None, version = None, long_commands = False, bsp_init =
> commands = []
> for cmd in waflib.Options.commands:
> - if cmd in ['build', 'clean', 'install']:
> + if cmd in ['build', 'clean', 'install', 'uninstall']:
> for x in arch_bsps:
> commands += [cmd + '-' + x]
> else:
