[PATCH 2/7] libdl/sparc: Print trace message of reloc failture path
chrisj at rtems.org
chrisj at rtems.org
Tue May 5 05:02:02 UTC 2020
Updates #3969
cpukit/libdl/rtl-mdreloc-sparc.c | 5 ++++-
1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cpukit/libdl/rtl-mdreloc-sparc.c b/cpukit/libdl/rtl-mdreloc-sparc.c
index 548c24132b..f8a4312a8a 100644
--- a/cpukit/libdl/rtl-mdreloc-sparc.c
+++ b/cpukit/libdl/rtl-mdreloc-sparc.c
@@ -232,8 +232,11 @@ rtems_rtl_elf_relocate_rela (rtems_rtl_obj* obj,
* We use the fact that relocation types are an `enum'
* Note: R_SPARC_6 is currently numerically largest.
- if (type > R_TYPE(6))
+ if (type > R_TYPE(TLS_TPOFF64)) {
+ if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
+ printf("rtl: invalid reloc type: %d\n", (int) type);
return rtems_rtl_elf_rel_failure;
value = rela->r_addend;
2.24.1
