[PATCH 5/7] libdl/obj-comp: Add trace prints when decompressing
chrisj at rtems.org chrisj at rtems.org
Tue May 5 05:02:05 UTC 2020
Updates #3969
 cpukit/include/rtems/rtl/rtl-trace.h |  2 ++
 cpukit/libdl/rtl-obj-comp.c          | 31 ++++++++++++++++++++++++++++
 2 files changed, 33 insertions(+)
diff --git a/cpukit/include/rtems/rtl/rtl-trace.h b/cpukit/include/rtems/rtl/rtl-trace.h
index 06c72c8992..196b4ff42e 100644
--- a/cpukit/include/rtems/rtl/rtl-trace.h
+++ b/cpukit/include/rtems/rtl/rtl-trace.h
@@ -54,7 +54,9 @@ typedef uint32_t rtems_rtl_trace_mask;
 #define RTEMS_RTL_TRACE_ARCHIVE_SYMS           (1UL << 13)
 #define RTEMS_RTL_TRACE_DEPENDENCY             (1UL << 14)
 #define RTEMS_RTL_TRACE_BIT_ALLOC              (1UL << 15)
+#define RTEMS_RTL_TRACE_COMP                   (1UL << 16)
 #define RTEMS_RTL_TRACE_ALL                    (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE | \
+        RTEMS_RTL_TRACE_COMP | \
        RTEMS_RTL_TRACE_GLOBAL_SYM | \
        RTEMS_RTL_TRACE_ARCHIVE_SYMS))
diff --git a/cpukit/libdl/rtl-obj-comp.c b/cpukit/libdl/rtl-obj-comp.c
index 36825baebe..4608a41bf4 100644
--- a/cpukit/libdl/rtl-obj-comp.c
+++ b/cpukit/libdl/rtl-obj-comp.c
@@ -21,10 +21,13 @@
 #include <unistd.h>
+#include <inttypes.h>
+#include <rtems/inttypes.h>
 #include <rtems/rtl/rtl-allocator.h>
 #include <rtems/rtl/rtl-obj-comp.h>
 #include "rtl-error.h"
+#include <rtems/rtl/rtl-trace.h>
 #include "fastlz.h"
@@ -91,6 +94,13 @@ rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
     return false;
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_COMP))
+    printf ("rtl:  comp: %2d: fd=%d length=%zu level=%u offset=%" PRIdoff_t " area=[%"
+            PRIdoff_t ",%" PRIdoff_t "] read=%" PRIu32 " size=%zu\n",
+            comp->fd, comp->cache->fd, length, comp->level, comp->offset,
+            comp->offset, comp->offset + length,
+            comp->read, comp->size);
   if (comp->fd != comp->cache->fd)
     comp->level = 0;
@@ -104,10 +114,18 @@ rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
     if (buffer_level)
+        printf ("rtl:  comp: copy: length=%zu\n",
+                buffer_level);
       memcpy (bin, comp->buffer, buffer_level);
       if ((comp->level - buffer_level) != 0)
+          printf ("rtl:  comp: copy-down: level=%u length=%zu\n",
+                  comp->level, comp->level - buffer_level);
         memmove (comp->buffer,
                  comp->buffer + buffer_level,
@@ -126,6 +144,10 @@ rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
       size_t   in_length = sizeof (block_size);
       int      decompressed;
+        printf ("rtl:  comp: read block-size: offset=%" PRIdoff_t "\n",
+                comp->offset);
       if (!rtems_rtl_obj_cache_read (comp->cache, comp->fd, comp->offset,
                                      (void**) &input, &in_length))
         return false;
@@ -136,6 +158,10 @@ rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
       in_length = block_size;
+        printf ("rtl:  comp: read block: offset=%" PRIdoff_t " size=%u\n",
+                comp->offset, block_size);
         return false;
@@ -172,6 +198,11 @@ rtems_rtl_obj_comp_read (rtems_rtl_obj_comp* comp,
       comp->offset += block_size;
       comp->level = decompressed;
+        printf ("rtl:  comp: expand: offset=%" PRIdoff_t \
+                " level=%u read=%" PRIu32 "\n",
+                comp->offset, comp->level, comp->read);
2.24.1
