m2005 untar error on msys2 (tar01 directory)
Chris Johns
chrisj at rtems.org
Tue May 5 06:01:10 UTC 2020
On 5/5/20 3:44 pm, Sebastian Huber wrote:
> On 05/05/2020 07:41, Chris Johns wrote:
>> On 5/5/20 3:34 pm, Sebastian Huber wrote:
>>> On 05/05/2020 07:22, Chris Johns wrote:
>>>> On 5/5/20 3:20 pm, Sebastian Huber wrote:
>>>>> In a msys2 shell I get:
>>>>> $ ../source-builder/sb-set-builder --prefix=/opt/rtems/5 5/rtems-sparc
>>>>> error: no hosts defaults found; please add
>>>> What does `python source-builder/sb/windows.py` show?
>>> $ python source-builder/sb/windows.py
>>> Traceback (most recent call last):
>>> File "source-builder/sb/windows.py", line 192, in <module>
>>> pprint.pprint(load())
>>> File "source-builder/sb/windows.py", line 64, in load
>>> raise error.general('invalid POSIX python for Windows')
>>> error.general: error: invalid POSIX python for Windows
>> What does `os.uname()` return?
> In the msys shell:
> $ python
> Python 3.7.4 (default, Jul 11 2019, 09:35:14)
That is what I have installed.
> [GCC 9.1.0] on msys
> Type "help", "copyright", "credits" or "license" for more information.
> >>> import os
> >>> os.uname()
> posix.uname_result(sysname='MSYS_NT-6.1-7601', nodename='Blub',
> release='3.0.7-338.x86_64', version='2019-07-11 10:58 UTC',
> machine='x86_64')
I have ...
>>> os.uname()
posix.uname_result(sysname='MINGW64_NT-10.0-18362', nodename='weng',
machine='x86_64')
I have never seen `MSYS_NT` before.
I am running Window-10 on real hardware running Version 1903, OS build
18362.778. I have not picked up the feature update yet. I am remote to
the machine and do not want to try.
> In the mingw64 shell:
> $ python
> Python 3.8.2 (default, Feb 27 2020, 05:27:33) [GCC 9.2.0 64 bit
> (AMD64)] on win32
This is wrong python, the os.name() check is only done on POSIX builds
of python.
> >>> import os
> >>> os.uname()
> File "<stdin>", line 1, in <module>
> AttributeError: module 'os' has no attribute 'uname'
Correct, it is not a posix build.
Using the m2005-1 snapshot I ran `windows.py` from same `msys` python
without error ...
{'___setup_shell': ('exe', 'required', '%{__sh}'),
'__bash': ('exe', 'required', 'bash'),
'__bison': ('exe', 'required', 'bison'),
'__bzip2': ('exe', 'required', 'bzip2'),
'__cat': ('exe', 'required', 'cat'),
'__cc': ('exe', 'required', 'x86_64-w64-mingw32-gcc'),
'__chgrp': ('exe', 'required', 'chgrp'),
'__chmod': ('exe', 'required', 'chmod'),
[snip]
'_usr': ('dir', 'optional', '/opt/local'),
'_var': ('dir', 'optional', '/opt/local/var'),
'_windows_os': ('none', 'none', 'mingw32'),
'gdb_python2': '/c/msys64/mingw64/bin/python2.exe',
'gdb_python3': '/c/msys64/mingw64/bin/python3.exe'}
