[PATCH 5/7] rtems: Add rtems_get_copyright_notice()
Tue May 5 14:23:30 UTC 2020
Update #3973.
 cpukit/Makefile.am                   |  1 +
 cpukit/include/rtems.h               |  5 ++++
 cpukit/libmisc/shell/shell.c         | 14 +++++++++--
 cpukit/sapi/src/getcopyrightnotice.c | 46 ++++++++++++++++++++++++++++++++++++
 testsuites/sptests/sp43/init.c       |  1 +
 testsuites/sptests/sp43/sp43.scn     |  1 +
 6 files changed, 66 insertions(+), 2 deletions(-)
 create mode 100644 cpukit/sapi/src/getcopyrightnotice.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 3af69bd615..51f38c84c7 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1051,6 +1051,7 @@ librtemscpu_a_SOURCES += sapi/src/extensionident.c
 librtemscpu_a_SOURCES += sapi/src/fatal.c
 librtemscpu_a_SOURCES += sapi/src/fatalsrctext.c
 librtemscpu_a_SOURCES += sapi/src/getconfigmax.c
+librtemscpu_a_SOURCES += sapi/src/getcopyrightnotice.c
 librtemscpu_a_SOURCES += sapi/src/getversionstring.c
 librtemscpu_a_SOURCES += sapi/src/interrtext.c
 librtemscpu_a_SOURCES += sapi/src/io.c
diff --git a/cpukit/include/rtems.h b/cpukit/include/rtems.h
index 9f6f9cc659..1b91965563 100644
--- a/cpukit/include/rtems.h
+++ b/cpukit/include/rtems.h
@@ -63,6 +63,11 @@
 extern "C" {
 #endif
+ * @brief Returns the pointer to the RTEMS copyright notice.
+const char *rtems_get_copyright_notice(void);
  * @brief Returns the pointer to the RTEMS version string.
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 79c1afcb5a..0b06e8b4d1 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -683,7 +683,12 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
                 fprintf(out,"RTEMS");
                 break;
               case 'V':
-                fprintf(out,"%s\n%s",rtems_get_version_string(), _Copyright_Notice);
+                fprintf(
+                  out,
+                  "%s\n%s",
+                  rtems_get_version_string(),
+                  rtems_get_copyright_notice()
                 break;
               case '@':
                 fprintf(out,"@");
@@ -738,7 +743,12 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
                 fprintf(out,rtems_get_version_string());
                 break;
               case 'v':
-                fprintf(out,"%s\n%s",rtems_get_version_string(),_Copyright_Notice);
+                fprintf(
+                  out,
+                  "%s\n%s",
 	        break;
 	      case '%':fprintf(out,"%%");
 	        break;
diff --git a/cpukit/sapi/src/getcopyrightnotice.c b/cpukit/sapi/src/getcopyrightnotice.c
new file mode 100644
index 0000000000..515d5258c2
--- /dev/null
+++ b/cpukit/sapi/src/getcopyrightnotice.c
@@ -0,0 +1,46 @@
+ * @file
+ * @ingroup RTEMSAPIClassic
+ * @brief rtems_get_copyright_notice() Implementation
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/copyrt.h>
+const char *rtems_get_copyright_notice( void )
+  return _Copyright_Notice;
diff --git a/testsuites/sptests/sp43/init.c b/testsuites/sptests/sp43/init.c
index b57c158173..57f883daf0 100644
--- a/testsuites/sptests/sp43/init.c
+++ b/testsuites/sptests/sp43/init.c
@@ -131,6 +131,7 @@ rtems_task Init(
   TEST_BEGIN();
   printf( "RTEMS Version: %s\n", rtems_get_version_string() );
+  printf( "RTEMS Copyright Notice: %s\n", rtems_get_copyright_notice() );
   main_task = rtems_task_self();
diff --git a/testsuites/sptests/sp43/sp43.scn b/testsuites/sptests/sp43/sp43.scn
index 04af7f9596..c71f087f96 100644
--- a/testsuites/sptests/sp43/sp43.scn
+++ b/testsuites/sptests/sp43/sp43.scn
@@ -1,5 +1,6 @@
 *** BEGIN OF TEST SP 43 ***
 RTEMS Version: rtems-5.0.0 (SPARC/w/FPU/erc32)
+RTEMS Copyright Notice: Copyright (C) 1989, 2020 RTEMS Project and contributors
 rtems_object_get_classic_name - INVALID_ADDRESS
 rtems_object_get_classic_name - INVALID_ID (bad index)
 rtems_object_get_classic_name - INVALID_ID (unallocated index)
2.16.4
