[PATCH 1/7] Use rtems_get_version_string()
Wed May 6 00:22:42 UTC 2020
This patch is OK for 5.1.
On 6/5/20 12:23 am, Sebastian Huber wrote:
> Update #3970.
>   bsps/powerpc/beatnik/start/bspstart.c          | 2 +-
>   bsps/powerpc/motorola_powerpc/start/bspstart.c | 2 +-
>   bsps/powerpc/mvme3100/start/bspstart.c         | 2 +-
>   bsps/powerpc/mvme5500/start/bspstart.c         | 2 +-
>   cpukit/libmisc/shell/shell.c                   | 6 +++---
>   5 files changed, 7 insertions(+), 7 deletions(-)
> diff --git a/bsps/powerpc/beatnik/start/bspstart.c b/bsps/powerpc/beatnik/start/bspstart.c
> index 4e0f007d41..520d908930 100644
> --- a/bsps/powerpc/beatnik/start/bspstart.c
> +++ b/bsps/powerpc/beatnik/start/bspstart.c
> @@ -207,7 +207,7 @@ static void bsp_early( void )
>     /* Make sure we detect a known host bridge */
>     BSP_getDiscoveryVersion(/* assert detection */ 1);
> -  printk("Welcome to RTEMS %s\n", _RTEMS_version );
> +  printk("Welcome to RTEMS %s\n", rtems_get_version_string() );
>     /* Leave all caches as MotLoad left them. Seems to be fine */
> diff --git a/bsps/powerpc/motorola_powerpc/start/bspstart.c b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> index c28d5d21b5..e74b02c446 100644
> --- a/bsps/powerpc/motorola_powerpc/start/bspstart.c
> +++ b/bsps/powerpc/motorola_powerpc/start/bspstart.c
> @@ -219,7 +219,7 @@ static void bsp_early( void )
>     myBoard = getMotorolaBoard();
>     printk("-----------------------------------------\n");
> -  printk("Welcome to %s on %s\n", _RTEMS_version,
> +  printk("Welcome to %s on %s\n", rtems_get_version_string(),
>                                       motorolaBoardToString(myBoard));
>   #ifdef SHOW_MORE_INIT_SETTINGS
> diff --git a/bsps/powerpc/mvme3100/start/bspstart.c b/bsps/powerpc/mvme3100/start/bspstart.c
> index f20a40fed1..0ec215e33b 100644
> --- a/bsps/powerpc/mvme3100/start/bspstart.c
> +++ b/bsps/powerpc/mvme3100/start/bspstart.c
> @@ -231,7 +231,7 @@ VpdBufRec          vpdData [] = {
>     myCpu = get_ppc_cpu_type();
>     myCpuRevision = get_ppc_cpu_revision();
> -  printk("Welcome to %s\n", _RTEMS_version);
> +  printk("Welcome to %s\n", rtems_get_version_string());
>     printk("BSP: %s, CVS Release ($Name$)\n", "mvme3100");
> diff --git a/bsps/powerpc/mvme5500/start/bspstart.c b/bsps/powerpc/mvme5500/start/bspstart.c
> index 90fc8cf961..3a9ef69f0f 100644
> --- a/bsps/powerpc/mvme5500/start/bspstart.c
> +++ b/bsps/powerpc/mvme5500/start/bspstart.c
> @@ -227,7 +227,7 @@ static void bsp_early( void )
>      * More PCI1 memory mapping to be done after BSP_pgtbl_activate.
> -  printk("Welcome to %s on MVME5500-0163\n", _RTEMS_version );
> +  printk("Welcome to %s on MVME5500-0163\n", rtems_get_version_string() );
>     BSP_mem_size         =  probeMemoryEnd();
> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
> index f00ae54b49..79c1afcb5a 100644
> --- a/cpukit/libmisc/shell/shell.c
> +++ b/cpukit/libmisc/shell/shell.c
> @@ -683,7 +683,7 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
>                   fprintf(out,"RTEMS");
>                   break;
>                 case 'V':
> -                fprintf(out,"%s\n%s",_RTEMS_version, _Copyright_Notice);
> +                fprintf(out,"%s\n%s",rtems_get_version_string(), _Copyright_Notice);
>                   break;
>                 case '@':
>                   fprintf(out,"@");
> @@ -735,10 +735,10 @@ static bool rtems_shell_login(rtems_shell_env_t *env, FILE * in,FILE * out)
>                   fprintf(out,"(" CPU_NAME "/" CPU_MODEL_NAME ")");
>                   break;
>                 case 'r':
> -                fprintf(out,_RTEMS_version);
> +                fprintf(out,rtems_get_version_string());
>                   break;
>                 case 'v':
> -                fprintf(out,"%s\n%s",_RTEMS_version,_Copyright_Notice);
> +                fprintf(out,"%s\n%s",rtems_get_version_string(),_Copyright_Notice);
>   	        break;
>   	      case '%':fprintf(out,"%%");
>   	        break;
