GSoC 2020: Implementation of OFW functions
Niteesh G. S. niteesh.gs at gmail.com
Wed May 6 07:16:45 UTC 2020
On Tue, May 5, 2020 at 11:44 PM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello Niteesh,
> On 05/05/2020 19:10, Niteesh G. S. wrote:
> > This is thread is about implementing OFW functions in RTEMS as part
> > of my GSoC project. I would like to start off with this part since the
> > refactoring
> > work will somewhat depend on this.
> I'm not sure whether everyone on the list is already fully aware of what
> your project is. For some of us the GSoC preparation phase is more of a
> background noise. So maybe you want to give a short (only a few
> sentences) overview of your target and what is the gain for the RTEMS
> project.
I am sorry. I'll make sure that I do that from the next mail onwards.
> > Implementing these functions into RTEMS will make porting drivers from
> > FreeBSD to RTEMS easy. Currently, the drivers ported from freebsd
> implement
> > the functions using libfdt variants but this causes a lot of code
> > duplication.
> > eg: bsps/arm/imx/start/imx_iomux.c
> > My initial thoughts were to implement these functions one by one. But
> then
> > Christian and Vijay mentioned about porting them from libbsd.
> Yes, there has been an offlist discussion whether the approach of a
> reimplementing them is a good idea.
Can you forward those mails if possible? Maybe I could gather some ideas
from it.
> > I went
> > through the OFW code in libbsd and have described my porting process
> below.
> If that can be ported, it would be a better approach then reimplementing.
> > Please have a look at it and let me know if I have missed something or
> you
> > would like to improve things.
> > The following files will be ported from libbsd
> > prefix = freebsd/sys/dev/ofw
> > <prefix>/openfirm.c
> > <prefix>/openfirm.h
> > <prefix>/ofw_fdt.c
> > <prefix>/ofwvar.h
> > The main idea is to port openfirm.h but the other files are dependencies
> > of openfirm.h
> > After going through some open firmware documentation. I guess as far as
> > RTEMS is
> > concerned we could avoid many functions like OF_init, OF_putchar, OF_test
> > and only care about functions defined under openfirm.h:105-142
> OK. Note that these functions often have a "node". Think about what that
> is and from where you would get it in an RTEMS driver. I think a lot of
> FreeBSD drivers get it from their (logical) bus system like ofwbus.
Yes, the FreeBSD drivers do get their node handles from the buses.
One way(hackish) to accomplish this would be to create a dummy dev
structure which will be initialized during driver initialization. And then
the
drivers could query the node handles from it. But as mentioned this would
be hackish and I don't think will scale well.
Another approach will be to import ofwbus itself, but then it would be a
huge
diversion from my current project. I don't mind working on this if this is
the
cleanest way to do it. But then we should also consider re-working on the
objectives.
> > But these functions have dependency on the automatically generated
> > ofw_if.h and KOBJS.
> > But after a close inspection, I guess the KOBJSLOOKUP macro in ofw_if.h
> > can be
> > redefined or replaced for RTEMS. Since all it does is call the
> > respective functions defined in ofw_fdt_methods(ofw_fdt.c).
> Note that the automatically generated interface is used for the FreeBSD
> device driver structure (or rather the bus interface). If you port the
> stuff to RTEMS you should think about whether
> a) it should replace the libbsd stuff. In that case: What changes would
> be necessary to libbsd.
I don't get this point. By RTEMS do you mean rtems.git and not
rtems-libbsd.git
right? Because it is already there in rtems-libbsd.
b) or whether it should live side by side.
> > I had just spent a few hours going through the code. If I had missed
> > something
> > please let me know.
> > Thanks,
> > Niteesh.
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200506/60ce79b8/attachment-0001.html>
