[PATCH 1/6] testsuite: Add the BSP architecture to the include path
chrisj at rtems.org
chrisj at rtems.org
Wed May 6 08:41:32 UTC 2020
Updates #2962
testsuites/aclocal/rtems-test-check.m4 | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/testsuites/aclocal/rtems-test-check.m4 b/testsuites/aclocal/rtems-test-check.m4
index a0feee5e15..99b3e31244 100644
--- a/testsuites/aclocal/rtems-test-check.m4
+++ b/testsuites/aclocal/rtems-test-check.m4
@@ -7,7 +7,7 @@ AC_DEFUN([RTEMS_TEST_CHECK],
AC_MSG_CHECKING([${RTEMS_CPU}/${RTEMS_BSP} $1 test])
tcheck="${RTEMS_SOURCE_ROOT}/testsuites/rtems-test-check"
tdata="${RTEMS_BSP}-testsuite.tcfg"
- tincludes="${RTEMS_SOURCE_ROOT}/bsps/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}/config:${RTEMS_SOURCE_ROOT}/testsuites"
+ tincludes="${RTEMS_SOURCE_ROOT}/bsps/${RTEMS_CPU}:${RTEMS_SOURCE_ROOT}/bsps/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}:${RTEMS_SOURCE_ROOT}/bsps/${RTEMS_CPU}/${RTEMS_BSP_FAMILY}/config:${RTEMS_SOURCE_ROOT}/testsuites"
if test -f $tcheck; then
check_result=`$tcheck exclude ${RTEMS_BSP} $tdata $tincludes $1`
else
2.24.1
