[PATCH 3/6] libdl: Add allocator check script
chrisj at rtems.org
chrisj at rtems.org
Wed May 6 08:41:34 UTC 2020
Use with the trace outout to check for allocation leaks.
cpukit/libdl/rtl-alloc-check.py | 96 +++++++++++++++++++++++++++++++++
1 file changed, 96 insertions(+)
create mode 100644 cpukit/libdl/rtl-alloc-check.py
diff --git a/cpukit/libdl/rtl-alloc-check.py b/cpukit/libdl/rtl-alloc-check.py
new file mode 100644
index 0000000000..c2145a768e
--- /dev/null
+++ b/cpukit/libdl/rtl-alloc-check.py
@@ -0,0 +1,96 @@
+# Copyright (c) 2019 Chris Johns <chrisj at rtems.org>.
+# All rights reserved.
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
+# Check the allocations for libdl:
+# 1. Turn on the allocation trace.
+# 2. Load and unload object files.
+# 3. Capture the trace output and feed to this tool
+from __future__ import print_function
+import argparse
+class libdl_trace(object):
+ def __init__(self, name):
+ self.name = name
+ self.trace = {'alloc': []}
+ def load(self):
+ with open(self.name, 'r') as f:
+ lc = 0
+ for line in f:
+ line = line[:-1]
+ lc += 1
+ if line.startswith('rtl: '):
+ if line.startswith('rtl: alloc: '):
+ self.trace['alloc'] += [(lc, line)]
+ def check_allocs(self):
+ allocs = {}
+ locks = 0
+ wr_enable = False
+ for lc, line in self.trace['alloc']:
+ ls = line.split(' ')
+ if len(ls) > 3:
+ if ls[2] == 'new:':
+ addr = ls[4].split('=')[1]
+ size = ls[5].split('=')[1]
+ count = 0
+ if addr in allocs:
+ alc, alloced, asize, count = allocs[addr]
+ if alloced:
+ print(
+ '%5d: already alloced: %5d: addr=%-9s size=%-9s count=%d'
+ % (lc, alc, addr, asize, count))
+ allocs[addr] = (lc, True, size, count + 1)
+ elif ls[2] == 'del:':
+ if addr != '0':
+ if addr not in allocs:
+ print('%5d: delete never alloced: addr=%s' %
+ (lc, addr))
+ else:
+ alc, alloced, size, count = allocs[addr]
+ if not alloced:
+ print(
+ '%5d: delete not alloced: %5d: addr=%-9s size=%-9s count=%d'
+ % (lc, alc, addr, size, count))
+ allocs[addr] = (lc, False, size, count)
+ alloced_remaiing = 0
+ addresses = sorted(list(allocs.keys()))
+ for addr in addresses:
+ lc, alloced, size, count = allocs[addr]
+ if alloced:
+ print('%5d: never deleted: addr=%-9s size=%-9s count=%d' %
+ (lc, addr, size, count))
+ alloced_remaiing += int(size)
+ if alloced_remaiing != 0:
+ print("Amount alloced: %d" % (alloced_remaiing))
+def run(args):
+ argsp = argparse.ArgumentParser(prog='rtl-alloc-check',
+ description='Audit libdl allocations')
+ argsp.add_argument('traces', help='libdl trace files', nargs='+')
+ opts = argsp.parse_args(args[1:])
+ for t in opts.traces:
+ trace = libdl_trace(t)
+ trace.load()
+ trace.check_allocs()
+if __name__ == "__main__":
+ import sys
+ run(sys.argv)
2.24.1
