GSoC 2020: Implementation of OFW functions
Niteesh G. S. niteesh.gs at gmail.com
Thu May 7 05:28:09 UTC 2020
On Thu, May 7, 2020 at 10:44 AM Sebastian Huber <
> On 07/05/2020 06:58, Niteesh G. S. wrote:
> > I couldn't go through it yesterday. Today I started off with building
> > rtems6
> > toolchain for arm using RSB but failed. I used the following command
> > ../source-builder/sb-set-builder
> > --prefix=/home/niteesh/development/rtems/6 6/rtems-arm --jobs=8
> > The problem seems to happen when trying to download the sources for
> > GCC. I have
> > attached the complete log file to this mail. I have also pasted the
> > last few lines below.
> > download: (full)
> > https://gcc.gnu.org/git/gitweb.cgi?p=gcc.git;a=snapshot;h=1dae549;sf=tgz
> > -> sources/gcc-1dae549.tar.gz
> > download:
> > download: no ssl context
> > download:
> > https://gcc.gnu.org/git/gitweb.cgi?p=gcc.git;a=snapshot;h=1dae549;sf=tgz:
> > error: HTTP Error 403: Forbidden
> > error: downloading
> > all paths have failed, giving up
> This is an unexpected download source. GCC should be downloaded from our
> Github mirror. Also the GCC Git hash should be e62a820. Which RSB commit
> did you use?
Sorry, it was my mistake I didn't update RSB. It works now.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200507/42358c59/attachment.html>
