GSoC 2020: Implementation of OFW functions
Niteesh G. S.
niteesh.gs at gmail.com
Thu May 7 15:19:11 UTC 2020
On Thu, May 7, 2020 at 4:07 PM Sebastian Huber <
> On 07/05/2020 12:28, Niteesh G. S. wrote:
> > On Thu, May 7, 2020 at 1:21 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > On 07/05/2020 09:35, Niteesh G. S. wrote:
> > > This is what I was trying to convey in one of the previous mails.
> > > https://lists.rtems.org/pipermail/devel/2020-May/059717.html
> > > But in that mail, I was planning to replace KOBJLOOKUP.
> > > Should I start working on it? From the top of my mind, the
> > following has
> > > to be done.
> > > 1) Import openfirm.c openfirm.h, ofw_fdt.c
> > > 2) Add ofw_fdt.h since all the functions in ofw_fdt are static.
> > > Should we also import ofw_if.h? Because that is where OFW_*
> > functions
> > > are defined or just add a ofw_rtems_map.h which redefines them,
> > instead
> > > of importing ofw_if.h?
> > The KOBJ stuff in the OFW support enables FreeBSD to have three
> > different implementations of the OFW API which can be selected at
> > runtime:
> > sys/powerpc/ofw/ofw_real.c
> > sys/dev/ofw/ofw_standard.c
> > sys/dev/ofw/ofw_fdt.c
> > In libbsd this is already short cut to the FDT implementation:
> > #ifndef __rtems__
> > static ofw_def_t *ofw_def_impl = NULL;
> > #else /* __rtems__ */
> > #define ofw_def_impl (&ofw_fdt)
> > #endif /* __rtems__ */
> > To me this looks like the KOBJ stuff was just used to enable some
> > sort
> > of object oriented programming. Do we need this flexibility at
> > runtime
> > in RTEMS? I would say no. I would hard wire this to the FDT
> > implementation. If someone has a problem with it in the future, this
> > decision can be readdressed.
> > Ok. But what is the neatest way to hardwire this to the FDT
> > implementation?
> > One way as Christian mentioned would be to redefine OFW_* functions to
> > call the functions in ofw_fdt.c directly. Is there any other way?
> I would try to replace the function declarations in openfirm.h with
> inline functions which call the ofw_fdt.c functions.
Should I proceed with the above method? or should I wait for others
to comment?
If I can proceed, the following is what I will be doing.
1) import openfirm.h and ofw_fdt.c into RTEMS.
2) Add ofw_fdt.h with functions declarations for functions in ofw_fdt.c
3) Add necessary compile-time guards. This would include using __rtems__
preprocessor directive to avoid FreeBSD stuff and change the function
definitions in ofw_fdt.c from static to non-static.
Am I missing something? or is there any other way to do this?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200507/cce84603/attachment-0001.html>
