[PATCH] networking: Increase _SYS_MBUF_LEGACY_MSIZE to 256 to match FreeBSD
Chris Johns
chrisj at rtems.org
Fri May 8 04:12:24 UTC 2020
Hi Hesham,
I do not understand the reason here. I thought the TCP header was a
fixed size?
On 8/5/20 6:12 am, heshamelmatary at gmail.com wrote:
> From: Hesham Almatary <Hesham.Almatary at cl.cam.ac.uk>
> This commit fixes some run-time errors on 64-bit architectures (e.g., riscv64)
> in which the tcp header size would overflow 128 bytes.
> cpukit/libnetworking/sys/mbuf.h | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libnetworking/sys/mbuf.h b/cpukit/libnetworking/sys/mbuf.h
> index c54b760b3..ef1641a91 100644
> --- a/cpukit/libnetworking/sys/mbuf.h
> +++ b/cpukit/libnetworking/sys/mbuf.h
> @@ -46,7 +46,7 @@
> * at least MINCLSIZE of data must be stored.
> -#define _SYS_MBUF_LEGACY_MSIZE 128
> +#define _SYS_MBUF_LEGACY_MSIZE 256
> #define MLEN (_SYS_MBUF_LEGACY_MSIZE - sizeof(struct m_hdr)) /* normal data len */
> #define MHLEN (MLEN - sizeof(struct pkthdr)) /* data len w/pkthdr */
> #define MINCLSIZE (MHLEN + MLEN) /* smallest amount to put in cluster */
