[PATCH] networking: Increase _SYS_MBUF_LEGACY_MSIZE to 256 to match FreeBSD
Sebastian Huber
Fri May 8 04:52:46 UTC 2020
On 08/05/2020 06:49, Hesham Almatary wrote:
> On Fri, 8 May 2020 at 05:42, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 07/05/2020 22:12, heshamelmatary at gmail.com wrote:
>>> From: Hesham Almatary<Hesham.Almatary at cl.cam.ac.uk>
>>> This commit fixes some run-time errors on 64-bit architectures (e.g., riscv64)
>>> in which the tcp header size would overflow 128 bytes.
>> I think it is a waste of time to use the old network stack with 64-bit
>> architectures. I guess there are a lot more problems in it.
> I agree. I am using libbsd instead, but that was a quick fix for one
> more sample app to succeed.
Do the network tests in the RTEMS test suite run with this change?
