GSoC: RTEMS directory for FreeBSD imports
Chris Johns
chrisj at rtems.org
Mon May 11 07:11:35 UTC 2020
On 11/5/20 4:55 pm, Christian Mauderer wrote:
> On 11/05/2020 06:57, Chris Johns wrote:
>> On 11/5/20 2:03 pm, Niteesh G. S. wrote:
>>> On Mon, May 11, 2020 at 4:34 AM Chris Johns <chrisj at rtems.org
>>> <mailto:chrisj at rtems.org>> wrote:
>>> On 10/5/20 6:17 pm, Niteesh G. S. wrote:
>>> > This thread is a continuation of "GSoC 2020: Implementation of OFW
>>> > functions".
>>> > A summary of points discussed in that thread is given below.
>>> > Below is a short description of my GSoC project. For more
>>> information please
>>> > refer to the wiki.
>>> > https://devel.rtems.org/wiki/GSoC/2020/Beagle_FDT_initialization
>>> > My GSoC project deals with refactoring the Beagle BSP to add
>>> support for FDT
>>> > based initialization. As part of this process, I will have to
>>> import the
>>> > pin mux driver
>>> > into RTEMS which currently is present in libBSD.
>>> > This would require having support for OFW functions which are
>>> currently
>>> > not implemented
>>> > in RTEMS. Some drivers(eg: imx_iomux.c) which require these
>>> functions
>>> > provide
>>> > a local implementation using libFDT.
>>> I hope you do not mind if I wind back a couple of steps...
>>> OFW? Is this http://wiki.laptop.org/go/Open_Firmware?
>>> How does OFW related to FDT?
>>> We are only interested in the device tree interface provided by the OF.
>>> Functions like OF_getprop, OF_parent, etc.
>> Why not call libfdt functions? I am wondering what there is in FreeBSD
>> that is calling these functions? I am not questioning the need, it is a
>> case of not understanding the dependency.
> The use case for the OF_... and ofw_... functions is more or less a
> simple import from FreeBSD drivers. Beneath that there are some quite
> nice shortcuts in the OF_... and ofw_... functions that would have to be
> re-implemented in each driver (like ofw_bus_node_status_okay()).
> Some drivers already use hacked versions of the functions. For example:
> bsps/sparc64/shared/clock/ckinit.c
> bsps/arm/imx/start/imx_iomux.c
> A use case where the OF_... stuff would have been handy:
> For the imx pin initialization I would have loved to just use the
> fdt_pinctrl_configure_tree() from FreeBSD. But that one had a lot of
> OF_.. stuff. Therefore I had to reimplement that function in a
> imx_pinctrl_configure_children(). My implementation basically does
> exactly the same thing but uses fdt_... functions instead of the OF_...
> functions.
Thanks. I think I understand. The scope seems to be the low level SoC
type initialisation. This makes sense.
>>> You discuss importing drivers from FreeBSD? Do you know which core
>>> FreeBSD pieces would need to also come over for the drivers listed
>>> below?
>>> We had discussed this in the previous thread.
>>> https://lists.rtems.org/pipermail/devel/2020-May/059765.html
>>> For OF_* functions we will only have to import the following files.
>>> 1) openfirm.h
>>> 2) ofw_fdt.c
>> You say below some drivers are being imported from FreeBSD, it is these
>> I am asking about.
>>> Is seamless integration with rtems-libbsd required or does it also
>>> include copies of the same code?
>>> I am sorry. I don't really understand what you are asking :(.
>> I am asking if the changes effect rtems-libbsd?
> I think the first step will be copies. It depends a bit on how well the
> functions can be integrated into RTEMS (the "node" parameter maybe is a
> bit difficult) but I'm confident that the OF_... and ofw_... stuff can
> be replaced sooner or later.
Sure, this is sensible. I am just mapping out in my head how this all
goes together.
>>> > In the previous thread, it has been decided to import the OFW
>>> functions from
>>> > FreeBSD but the directory where it has to be imported into RTEMS
>>> is not yet
>>> > decided. This thread has been created to discuss it.
>>> > It should also be noted that some drivers for example I2C, SPI
>>> are being
>>> > imported
>>> > into RTEMS from FreeBSD for some BSPs.
>>> > Now, since a large amount of code being imported from FreeBSD
>>> it is
>>> > planned to
>>> > add to a synchronization script(Yet to discussed in detail) to
>>> stay in
>>> > sync with
>>> > FreeBSD.
>>> > So now is it necessary to choose a directory that is future
>>> compatible
>>> > with the
>>> > synchronization script. We should also discuss if we want to have
>>> all
>>> > imports
>>> > under a single directory or have the imports in their respective
>>> > directories for eg
>>> > a device driver could be placed in its BSP directories than in a
>>> common
>>> > folder
>>> > along with other imports. But it should also be noted that the
>>> latter
>>> > makes it
>>> > difficult to sync and the former.
>>> Gedare covered these issues in the other thread in an excellent post
>>> [1]
>>> and I would like to reference that as I agree with it.
>>> When importing from such a large and complex code base like
>>> FreeBSD we
>>> need to be careful we do not pull on a thread and pull in large
>>> pieces
>>> of FreeBSD.
>>> Gedare's point about making sure all imported pieces are from the
>>> same
>>> version is important and I think a base requirement.
>>> I am OK with some code being in rtems.git if there is a clear use
>>> outside of rtems-libbsd. FDT support is one use, another is the NFS
>>> client code in FreeBSD being used with the legacy stack (there are
>>> BSPs
>>> with only legacy driver support still in use) and the existing
>>> client is
>>> only NFSv2.
>>> We need a place to collect the common base parts of FreeBSD that are
>>> shared by the various imported pieces. Isolated pieces could lead to
>>> repeated imports common pieces if we do not do this.
>>> I believe Sebastian said the new build system should handle the
>>> synchronisation? This is a good idea. Could it manage separated
>>> pieces?
>>> Could the build system read in all the sync pieces and logically join
>>> them based on the upstream source and operate on them as a group?
>>> This
>>> way we can have drivers in a BSP, NFS in libnfs (or where ever).
>>> I am not really familiar with the new build system. So can we please wait
>>> until Sebastian answers this.
>> Sure.
> Although note that I suggested to see the discussion as a _preparation_
> for that import. Doing the import right is quite a bit of work. It would
> change the target of Niteeshs GSoC project quite a lot. So we should
> make sure that a good location is selected and that the same rules like
> in libbsd are used. But I don't think that the actual script will be
> added in that project.
Again this is sensible. Thank you for clarifying things.
