[PATCH 4/6] testsuite: Add expected-fail to psim
Tue May 12 14:11:55 UTC 2020
On Tue, May 12, 2020 at 3:11 AM Chris Johns <chrisj at rtems.org> wrote:
> On 12/5/20 5:15 pm, Sebastian Huber wrote:
> > Hello,
> > On 09/05/2020 03:30, Gedare Bloom wrote:
> >>>>> Without these tests being tagged this way the user would have no
> >>>>> idea where the stand after a build and test run and that would mean
> >>>>> we would have to make sure a release has no failures. I consider
> >>>>> that as not practical or realistic.
> >>>> Maybe we need another state, e.g. something-is-broken-please-fix-it.
> >>> I do not think so, it is implicit in the failure or the test is
> >>> broken. The only change is to add unexpected-pass, that will be on
> >>> master after the 5 branch.
> >> I disagree with this in principle, and it should be reverted after we
> >> branch 5. It's fine for now to get the release state sync'd, but we
> >> should find a long-term solution that distinguishes the cases:
> >> 1. we don't expect this test to pass on this bsp
> >> 2. we expect this test to pass, but know it doesn't currently
> >> They are two very different things, and I don't like conflating them
> >> into one "expected-fail" case
> > originally, I had the same point of view. What I didn't take into
> > account was the perspective of the tester. Now, I think it is perfectly
> > fine to flag these tests as expected failure test states. Because right
> > now, due to some known bugs such as https://devel.rtems.org/ticket/3982
> > and probably also some more issues, these tests fail. On this BSP and
> > this RTEMS version, they will always fail. This is not some sort of
> > random failure. When we change test states to expected failure I think
> > we should make sure that a ticket exists, which captures that there are
> > some test results which indicate issues (expected failure test state).
> > The ticket system is the better place to manage this. We should not use
> > the test states for this. The test states should be used to figure out
> > changes between different test runs. They should enable also to quickly
> > check if the outcome of a test run yields the expected results for a
> > certain RTEMS version and BSP.
> Thanks. It is clear to me we lack documentation on this topic and this
> is an oversight on my part which I will attempt to correct.
This makes enough sense to me.
> I have reviewed Dejagnu and considered other things like the withdrawn
> IEEE 1003.3 standard and there are states we have that need to change
> but I think the original intent is the right path.
> The Dejagnu states are documented here:
> https://www.gnu.org/software/dejagnu/manual/A-POSIX-Conforming-Test-Framework.html#A-POSIX-Conforming-Test-Framework
> And the exit codes are:
> https://www.gnu.org/software/dejagnu/manual/Runtest.html#Runtest
> For me they define the goal and intent.
> The test states are metadata for the tester so it can determine the
> result of any given set of tests in relation to the expected state of
> the test when it was built. You need to detach yourself from being a
> developer and put yourself in the position of a tester who's task is to
> give an overall pass or fail for a specific build of RTEMS without
> needing to consider the specifics of any test, bug or feature.
> The primary requirement is to allow machine check of the results to
> determine regressions. A regression is a failure, pass or unresolved
> result that was not expected.
> My current thinking for test states are:
> PASS:
> The test has succeeded and passed without a failure.
> UNEXCEPTED-PASS:
in case you copy-paste, there are a few of these typos for EXPECTED
> The test has succeeded when it was expected to fail.
> FAIL:
> The test has not succeeded and has failed when it was expected to pass.
> The failure can be a failed assert, unhandled exception, resource
> constraint, or a faulty test.
> EXCEPTED-FAIL:
> The test has not succeeded and has failed and this is expected.
> UNRESOLVED:
> The test has not completed and the result cannot be determined. The
> result can be unresolved because the test did not start or end, test
> harness failure, insufficient computing resources for the test harness
> to function correctly.
> EXCEPTED-UNRESOLVED:
> The test has not completed and the result cannot be determined and this
> is expected.
> INDETERMINATE:
> The test has succeeded, has failed or in unresolved. The test is an edge
> case where the test can pass, can fail, can be unresolved and this is
> expected.
> USER-INPUT:
> The test has not completed and the result is unresolved because it
> requires user intervention that cannot be provided.
This USER-INPUT could also be EXPECTED-UNRESOLVED?
> BENCHMARK:
> The test performs a performance type test. These are currently not
> supported.
> UNTESTED:
> The test has not run and is a place holder for a real test that is not
> yet provided.
> UNSUPPORTED:
> The test is not supported for this build of RTEMS, BSP or architecture.
> Note:
> 1. Any expected failures, unresolved, or indeterminate test results are
> considered faults and require fixing.
> 2. The nature of a failure cannot be inferred from the test's metadata
> state.
> 3. The timeout and invalid states will be merged into UNRESOLVED.
> 4. The excluded state will be changed to UNSUPPORTED.
> 5. The metadata is placed in each test because is it an effective way to
> capture the state. Tests can be run as a group, stand alone or at
> different location and the test results can determine a regression. The
> version of the test harness does not need to match the RTEMS build.
> This list of test states account for some missing states. It also adds
> some states I do not see being available until we move to a new build
> system. For UNTESTED and UNSUPPORTED I see a template test being built
> and run and does nothing. This is important because it means we get a
> complete set of test results that are complete and consistent for all BSPs.
> I can attend to this change before releasing 5.1 or it can be done on
> master and we can determine if it is back ported to 5.2[34..].
I'm with Joel, this should defer until after release
> The change will come with documentation to explain thing a little better.
> I hope this addresses the issues we have and I am sorry for creating a
> disturbance so close to a release.
Thanks for bringing this out it is an important area to keep improving.
> Chris
