Adding fenv support for ARM
Joel Sherrill
joel at rtems.org
Tue May 12 22:20:03 UTC 2020
Gedare is right but one more piece of information is needed. When newlib is
being built, it lays target dependent files on top of generic ones. So the
default sys/fenv.h is replaced with something like
libc/machine/arm/sys/fenv.h. Make sure that
/home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h is
in fact the file you think it should be.
Also look at what is supposed to be in the generic fenv.h and <sys/fenv.h>.
You will probably have to tweak it some.
Check out what is in x86_64/fenv.h and riscv/fenv.h with respect to the
default environment variable. It looks to be declared differently in the
other ports so you may have to make it match.
But more output does help.
--joel
On Tue, May 12, 2020 at 4:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> Take the first error reported, and show what is being compiled. You've
> trimmed off too much preceding this to know what is being compiled and
> how this might be influencing your error.
> The specific error you're getting is often due to some syntax errors
> preceding the line shown.
> On Tue, May 12, 2020 at 2:59 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> > Hello everyone,
> > After adding the files and compiling. I am
> > getting a few errors which I am not able to rectify.
> > If you could take a look and tell how to sort them.
> > link to newlib's git repo:
> https://github.com/eshandhawan51/newlib-cygwin/tree/add_fenv_support
> > errors :
> > In file included from
> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:15:0,
> > from
> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:
> /home/eshan/development/newlib/c-arm-rtems5-newlib/arm-rtems5/thumb/newlib/targ-include/sys/fenv.h:82:1:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'extern'
> > extern const fenv_t *_fe_dfl_env;
> ../../../../../../newlib-cygwin/newlib/libm/fenv/feclearexcept.c:57:0:
> /home/eshan/development/newlib/newlib-cygwin/newlib/libc/include/fenv.h:22:1:
> error: expected '=', ',', ';', 'asm' or '__attribute__' before 'int'
> > int feclearexcept(int excepts);
> > thanks
> > -Eshan
> > On Sat, May 9, 2020 at 2:53 AM Joel Sherrill <joel at rtems.org> wrote:
> >> On Thu, May 7, 2020 at 1:33 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
> >>> Hello everyone,
> >>> This the tread to discuss adding fenv support for ARM architecture in
> newlib.
> >>> Link to previous thread:
> https://lists.rtems.org/pipermail/devel/2020-March/058473.html
> >>> ---FreeBSD Source
> >>> # https://github.com/freebsd/freebsd/tree/master/lib/msun/arm
> https://github.com/freebsd/freebsd/blob/master/sys/arm/include/ieeefp.h
> >>> ---NetBSD Source
> >>> # https://github.com/NetBSD/src/tree/trunk/lib/libm/arch/arm
> >>> --- Musl has no implementation for fenv support for ARM in it
> >>> After going through the implementations both FreeBSD and NetBSD have a
> stub implementation.
> >>> But then FreeBSD implementation seems to be more portable compared to
> that in NetBSD.
> >>> Should I start porting it from FreeBSD?
> >>> And which ARM BSP should I use for testing the changes?
> >>> Currently, I have xilinx_zynq_a9_qemu build
> >> I think the FreeBSD implementation is the one to use. It looks to
> support hard and soft floating point implementations.
> >> I think the fenv.h file there will have to be worked on so some of the
> contents go into sys or machine/fenv.h. There is a portable fenv.h.
> >>> There would also be a requirement to discuss where to place the files
> in Newlib.
> >> Not much to discuss. It should go into
> newlib-cygwin/newlib/libm/machine/arm.
> >>> Thanks
> >>> -Eshan
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200512/b0c12bfb/attachment-0001.html>
