[PATCH] posix: Get real priority in pthread_getattr_np()
    Heinz Junkes
    junkes at fhi-berlin.mpg.de
    Wed May 13 15:10:15 UTC 2020
Thanks for the good ideas.
I have now replaced the accesses to the internal thread structure (real_priority, current_priority) with API - calls.
One of the calls is from the pthread-library and therefore needs --enable-posix when creating the BSP.
Calls used
pthread_getschedparam
rtems_task_set_priority
Heinz
> On 12. May 2020, at 07:28, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> This is in line with pthread_setschedparam() and
> pthread_getschedparam().
> Update #2514.
> cpukit/posix/src/pthreadgetattrnp.c | 10 ++++++----
> 1 file changed, 6 insertions(+), 4 deletions(-)
> diff --git a/cpukit/posix/src/pthreadgetattrnp.c b/cpukit/posix/src/pthreadgetattrnp.c
> index a449ad48eb..eae29d1de7 100644
> --- a/cpukit/posix/src/pthreadgetattrnp.c
> +++ b/cpukit/posix/src/pthreadgetattrnp.c
> @@ -40,6 +40,7 @@ int pthread_getattr_np(
>   ISR_lock_Context              lock_context;
>   Thread_CPU_budget_algorithms  budget_algorithm;
>   const Scheduler_Control      *scheduler;
> +  Priority_Control              priority;
>   bool                          ok;
>   if ( attr == NULL ) {
> @@ -66,15 +67,12 @@ int pthread_getattr_np(
>   scheduler = _Thread_Scheduler_get_home( the_thread );
> -  attr->schedparam.sched_priority = _POSIX_Priority_From_core(
> -    scheduler,
> -    _Thread_Get_priority( the_thread )
>   _POSIX_Threads_Get_sched_param_sporadic(
>     the_thread,
>     scheduler,
>     &attr->schedparam
> +  priority = the_thread->Real_priority.priority;
>   if ( _Thread_Is_joinable( the_thread ) ) {
>     attr->detachstate = PTHREAD_CREATE_JOINABLE;
> @@ -97,6 +95,10 @@ int pthread_getattr_np(
>   attr->is_initialized = true;
>   attr->contentionscope = PTHREAD_SCOPE_PROCESS;
>   attr->cputime_clock_allowed = 1;
> +  attr->schedparam.sched_priority = _POSIX_Priority_From_core(
> +    scheduler,
> +    priority
>   attr->schedpolicy =
>     _POSIX_Thread_Translate_to_sched_policy( budget_algorithm );
> 2.26.1
> devel mailing list
> devel at rtems.org
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200513/189bf7ed/attachment.bin>
